02-21-2008, 02:40 PM | #1 |
Rep 79
Help me! Information wheels Z4 M
I have a problem, BBS CH
http://www.tirerack.com/images/wheel...s_ch_ci3_l.jpg 8.5x19 Offset: 35mm 19x10 Offset: 20mm Are they ok for Z4 M? Thanks! Last edited by Gabri343; 02-21-2008 at 03:01 PM.. |
02-22-2008, 09:51 AM | #2 |
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
You should post in the Wheels/Tires forum... I am sure it would get more replies... and you would also be following forum guidelines
2007 Z4 3.0si Coupe 6 MT Black Saphire Metallic PP SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide Denim Black V&H Tune 2021 BMW x30i Phytonic Blue Metallic Fully loaded |
03-14-2008, 05:49 PM | #3 |
24
Rep 1,604
If my calculations are correct the front wheels are within 1mm of the OEM wheels' fitment while the rear wheels are less than 3mm from the OEM wheels' fitment so you should be ok.
OEM: Front: 8*25.4/2 + 42 = 143,6mm Rear: 9*25.4/2 + 30 = 144,3mm Your wheels: Front: 8.5*25.4/2 + 35 = 143,0mm Rear: 10*25.4/2 + 20 = 147mm Cheers. |
04-09-2008, 10:28 AM | #4 |
2289
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
i've been sweating ch's in 19 for a long time, but way too expensive. and nobody has a used set =T
04-09-2008, 11:08 AM | #5 | |
2434
Rep 11,668
Use this calculator to estimate effects of offsets & wheel size. 10" ET20 are VERY aggressive & will likely rub A 10" et20 wheel will EXTEND out an extra 34mm!!!
'21 M2C Hockenheim Silver
'18 718 Cayman S Lava Orange (sold) '13 E92 M3 Santorini Blue (sold) '07 Z4 M Coupe Alpine White (sold) |
04-12-2008, 04:27 PM | #6 | |
Rep 613
06-18-2008, 04:32 AM | #7 | |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
