      10-07-2015, 12:43 AM   #1
AyJay87
AyJay87's Avatar
Drives: 2012 135i DCT Le Mans Blue
AutoX Tire Wear
Recently went autocrossing and I noticed a darker, 1" wide band/region towards the outside shoulder of the tires. What does your intuition say this is? And the cause?
My best guess is not enough negative camber or just build up of rubber from the course. Here's some data:
225 MPSS front
245 MPSS rear
28mm front sway bar
15 mm rear sway bar
-2.1 deg front camber
-1.7 deg rear camber
pavement temp about 125 deg F
95 deg F ambient
https://www.instagram.com/the_driving_gallery/ '12 135i DCT Le Mans Blue * M Sport Package * BMW Performance Exhaust * PPK 1 * ST Coilovers * Cobb Sway Bars * Dinan Camber Plates * VMR V705 Wheels * Michelin PSS
      10-07-2015, 08:27 AM   #2
alpho
Drives: AW 135i
Is it on both front and rear? or only front? what tire pressure's were you running?
      10-07-2015, 09:02 AM   #3
Kgolf31
Kgolf31's Avatar
460
Drives: 2007 Z4MC, 2012 128i
Most likely a compound change at the edge of the shoulder.
And yes, no where near enough camber.
Pictures would be helpful
      10-07-2015, 09:44 AM   #4
AyJay87
AyJay87's Avatar
It is more on the fronts than the rears. Cold tire pressures: 36 psi front, 39 psi rear.
      10-07-2015, 09:45 AM   #5
AyJay87
AyJay87's Avatar
That right, there is a different compound on the outside edge. What camber would you recommend? I'll see if I can get a good picture later.
      10-09-2015, 10:45 AM   #6
dtla1
dtla1's Avatar
828
Drives: 2011 135i, Space Grey
The experts might chime in here, but I think that cold tire pressure is a little too high. Also, more camber. And MPSS shoulders are very soft, easy for you to roll the tire over.
      10-10-2015, 03:22 PM   #7
AyJay87
AyJay87's Avatar
What pressure should I run cold?
      10-10-2015, 03:25 PM   #8
AyJay87
AyJay87's Avatar
Finally got a picture, though its not great. Its dusty/dirty. You can kind of see it. The flash kind of hides it towards the middle-top of the pic.
      10-10-2015, 11:02 PM   #9
Kgolf31
Kgolf31's Avatar
460
It's extra heat generated on the outside shoulder. I've had tires in that spot turn to purple
      10-11-2015, 02:32 PM   #10
lowside67
219
Drives: 2011 BMW 128i
That looks to me to easily be attributed to camber, not pressure. You are going to need in excess of 3 degrees to properly evenly wear your front tires.
Mark
1addicts
