03-05-2016, 11:45 AM | #1 |
Stop the hate, get a V8
3851
Rep 8,625
Any rear differential temperature sensors?
Are there any sensors in the rear diff to monitor temperature? Has anyone ever logged any data to see what the typical temperatures look like for street driving and perhaps on the track?
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
03-05-2016, 11:53 AM | #2 |
Rep 7,119
Yes, that would be interesting to know about! Mine is grumpy and grining when cold, even more after fluid change (assumingly with FM but still), which I kinda like as then it works. After some driving it calms down and becomes silent. But what temps are we talking about?
Hopefully some of the experts can chime in! |
03-05-2016, 12:04 PM | #3 | |
829
Rep 3,387
https://europeanautosource.com/awron...mw-e9x-m3.html |
03-05-2016, 12:20 PM | #4 | |
3851
Rep 8,625
Interesting. Is that pulling data from an existing sensor? Can Carly or other apps query it?
03-05-2016, 04:20 PM | #6 |
829
Rep 3,387
03-07-2016, 10:03 AM | #8 |
3851
Rep 8,625
Then how is that AWRON gauge doing it?
03-07-2016, 02:06 PM | #9 |
Retired Curmudgeon
2985
Rep 4,047
Likely they have the "capability" to take data from a sensor you install in the diff.
FWIW, I had a temp sensor in the E36M3 race car years ago. Before installing the Rogue Engineering finned differential cover (which looks very similar to the M-diff cover), I saw scary diff oil temps (e.g., 275 deg F). Not as scary as the transmission oil temps (300+ deg F ), but scary nevertheless. Once I put on the Rogue diff cover, temps dropped, never topping 250 deg F on the worst day (109 deg F green flag air temp). Standard was around 240 deg F iirc. Now the M-variable diff may be completely different as far as temps go. The temps I quoted above were from a stock, non-M variable diff (since they weren't on the E36's) 3.15 LSD and also from a custom Diffs Online 3.73 diff with different ramp rates than stock. FWIW, the Diffs Online diff was awesome! Loved it. Hope this helps.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
03-07-2016, 02:16 PM | #10 |
3851
Rep 8,625
Interesting info, thanks.
What was the FD in that car? A larger ratio will run hotter. The M-DCT's FD is only 3.154:1. Also, was that car spec'd for 75w140 like ours?
03-07-2016, 03:32 PM | #13 | |
3851
Rep 8,625
Interesting, though that doesn't completely surprise me. The DSC module knows what the wheels are doing, how much yaw there is, etc., so it could infer what the LSD is doing. There must be some complex logic in there to estimate the temps!
03-07-2016, 10:09 PM | #14 | |
Retired Curmudgeon
2985
Rep 4,047
I'm pretty sure that that diff used 75w-90 oil.
03-12-2016, 03:17 PM | #16 | |
3851
Rep 8,625
Thanks. Was hoping there was a sensor there from the factory.
