M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      03-14-2016, 05:14 AM   #1
drbru
Drives: f10 m5
Car is randomly unlocking itself
As per the title....So this has happened a few times now but strangely enough it only seems to happen when im hovering around the car...
I initially thought I may be pressing the button by accident when the keys were in my pocket but even when I hold the key in my hands it still happens sometime...
incidently as well...the comfort access mechanism on one of the doors has stopped working..I can open from this door but cant lock from this door but this may be a separate issue...
Just worried that one day I may go to my car to find it has unlocked itself!
Can any of this be related to battery? Ive had no warnings but would it be worth me changing the battery on my key fob anyway to see if it helps?
Cheers
      03-14-2016, 12:29 PM   #2
mbrodie121
US Barvarian
mbrodie121's Avatar
Drives: F15 50i, E92 335i, E46 M3
Had similar issue with my F10. Ended up being a bad comfort access door handle. It would lock and unlock right after I got out of the car, lock as i came close to the car, and other erratic behavior.
I thought mine was battery related at first.
Took into BMW to confirm and they told me it was drivers door handle CA issue. They also told me it would need to be coded (which it did not)
I ordered one off getbmwparts, disconnected battery, installed, and all has been well.
Hope this helps!
Good luck.
-mbrodie121
_______________
2014 X5 50i M-Sport BSM/BK : 2007 E92 335i Montego/Saddle/M359/JB4 G5-ISO-FMIC-DP-CP-DCI : 2004 E46 M3 Convertible JB/Cinnamon/19 ZHP Wheels
      03-14-2016, 12:42 PM   #3
drbru
Drives: f10 m5
Hope this helps!
Good luck.
Thanks mate, looks like I may need to get the car in BMW for them to diagnose...Got warranty though so hopefully shouldn't cost anything
      03-14-2016, 12:57 PM   #4
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
I have read about others with the same issue. It is a comfort access issue as stated earlier. Should be covered under warranty as theirs was as well.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      03-14-2016, 05:14 PM   #5
Rearview
Drives: F10 M5
Hmm ... my 550i xDrive and my M5 both do this when washing and fob is in proximity. Not touching door handle ... thought it was normal as all of my Corvettes have done the same ...
      03-15-2016, 04:02 AM   #6
drbru
Drives: f10 m5
Washing I can understand. If Im using a jet wash on the car and it touches the door handle it will unlock...
But the problem I currently have is that I literally stand by the car and every now and again it will unlock
      03-16-2016, 03:16 PM   #7
a90
Netherlands
66
Drives: F10 M5, E88 125, E70 X5, R1150
I have that sometimes when the war is washed and waxed in a washbox drivetru. For some reason the wax on the doorhandles is triggering the comfort access. Cleaning the handle does work for me.
BMW E88 125 - 2008
BMW F10 M5 - 2016
BMW E70 X5 3.0d - 2007
BMW R1150r Rockster - 2003
Mercedes LP2223 - 1970 (http://www.lp2223.com)
      06-30-2018, 09:13 PM   #8
paporucho
Drives: Bmw 535i 2014 msport
Help here!!!
I have the same issue as you but is only when I get close fron the passager side . The car start unlocking itself again and again and again ( with the key in my pocket). Also when I turn the Engine start but have a message telling me that the key is bad ( start and drive perfectly fine) im out of warranty so what do you recommend me. Texted with my 2 keys with new batteries same result
      06-30-2018, 09:15 PM   #9
paporucho
Help!
      07-01-2018, 05:47 PM   #10
TLK
TLK's Avatar
112
Drives: '14 M5 CP, '12 550i, '04 545i
A door handle is probably bad. It only happens when the fob is in range. This can be observed on ista if you or someone you know has it. In not, any decent Indy bmw shop or dealer can deal with this for you if you have a consistent problem now.
      07-01-2018, 05:50 PM   #11
TLK
TLK's Avatar
112
For washing I find it's better to leave the fob inside the house out of range to avoid unnecessary lock action or accidentally opening the trunk.
      07-02-2018, 12:53 AM   #12
black1
black1's Avatar
59
Drives: Pure Metal M6GC
had the same problem, also a door handle replacement.
      07-12-2021, 12:05 PM   #13
SJUHawk96
Drives: BMW 535i xDrive
Comfort Access Issue
My 2012 535i xDrive has a similar issue. If I walk near the right rear quarter panel the car repeatedly tries to unlock (whether locked or unlocked). The right rear door handle was replaced under CPO, and I have disconnected the handle and this does not resolve the problem. I also get notifications that the remote is not recognized by the car and will not start without placing the remote near the steering column. I occasionally get the battery low / disconnected message. Most of this, except the unlocking, is intermittent. About to disconnect the front door as well to confirm that's not the issue (I really don't think it is as the unlocking starts as soon as I walk around the rear of the car), but could it be related to the computer / fuse panel located in the rear passenger quarter?
      07-12-2021, 12:49 PM   #14
ruben356
Drives: F13 M6 _ San Marino Blue
Have same issue and similar symptoms. My driver door handle CA is dead, i believe this is the issue. I will be replacing the handle and going from there. I thought my key fob battery was dead, a few times wouldn't let me start the car, and sometimes won't lock despite multiple button presses.
m5post
