04-08-2016, 08:43 PM | #1 |
Rep 241
Replacing M5 Kidney Grilles with LCIs ... how did you do it?
what process did you follow when replacing? The IND - yank them straight out version OR the loosen the top of the front bumper and reach in version? I am leaning toward the yank out method.
04-08-2016, 10:59 PM | #4 |
Rep 812
I just got my LCI grills and I am gonna do the Yank method and probably after car has been running so area is warm and more pliable
Formally known as BMWM3NYC
04-08-2016, 11:20 PM | #5 | |
Rep 3,834
Open the hood, remove the weather strip covering the screws, remove the Torx screws. Pull the bumper out enough to reach down to the back of the grill, use your fingers to release the top and side clips. You won't be able to remove the bottom clips, so now is the time to gently yank. Wear long sleeves or your arm will be scratched up.
Daily: G12 750 MSPORT Weekend Car: E90 M3
04-08-2016, 11:43 PM | #6 | |
Rep 812
J11SEK268.00 |
04-09-2016, 12:51 AM | #7 |
Licensed Drug Dealer
742
Rep 2,269
I did both the IND way and the bumper removal way, and obviously when you do the bumper removal way, the chances of you breaking the tabs are less.
I didn't break mine however, when I did the IND way. I just heard a really loud crack when it came off! I thought I broke some tabs, but I didn't. |
04-09-2016, 01:11 AM | #8 |
363
Rep 1,805
Drives: 2014 BMW M5 F10 CP
Follow this thread and you'll be 100s
2014 BMW F10 M5 ZCP | SSII / Black | MSR Stage III | MSR Intakes | RPi GTM Exhaust | RPi Catless Downpipes |RW Carbon Front Lip | RW Carbon Diffuser | RW Carbon Trunk Spoiler |
04-09-2016, 09:24 AM | #9 |
Rep 995
You can use painters tape around the grille area to make sure you don't scratch the paint. Just pull straight out. It helps if the car has been sitting in the heat so the bumper has more flex.
04-09-2016, 10:19 AM | #10 |
Insta pjahdish
184
Rep 116
I was a bit worried about yanking them out but my impatience wouldn't allow me to wait and have someone else install or to loosen the bumper. Wore a pair of gloves and pulled straight out. Was surprised how easy they came out. Didn't break a single clip. Did both sides in a few minutes.
04-09-2016, 10:33 AM | #11 | |
Rep 3,834
The yanking method works, but if you're unlucky the bumper slots that hold the grille tabs will tear. I tore the bumper tabs on my F10 535i with the yank method, so I started loosening the top of the bumper for my F80 M3, 750Li, X5M, and M5. It only takes 5min longer to loosen the screws, but it's the "correct" way to remove the grilles without damaging the plastic bumper tabs that house the grilles. When I did body work in high school, my boss always told me to never "force" anything out of the car. There's always a better way to remove it.
04-09-2016, 12:42 PM | #12 | |
Rep 812
04-09-2016, 03:50 PM | #14 |
Rep 2,039
I went through the top of the bumper and reached down to push on the tabs. It was a bit of a struggle and I ended up with bruises and cuts on both forearms. They say love hurts, I guess they're right.
04-09-2016, 04:21 PM | #15 |
Rep 1,108
Yank from the front? Lol. People are geniuses on here.
If you don't want to break anything, remove the weather stripping and take out the screws. It'll take longer and you'll probably lose a pint of blood, but at least you won't fuck anything up. What would you rather scratch up, your hands or your car? #priorities |
04-10-2016, 09:57 AM | #17 |
Rep 195
used both method, pre LCI black paint grill, I just yank them out when the car is warm
but for the LCI grill with M5 badge, had to remove screws to gain access to the clips, I guess the double slut structure is stronger, prepare to get some cut |
04-10-2016, 02:09 PM | #18 | |
Rep 3,834
I learned after my first grill replacement to wear long sleeves. When the bumper is warm, you can pull the top out further.
04-10-2016, 11:44 PM | #19 |
9159
Rep 14,521
sorry...that just sounded funny!
04-15-2016, 08:06 PM | #21 |
Hide! My wife's coming!
812
Rep 2,816
Used gloves and slowly pulled on the top and then bottom of the grills. Have done. It several times. No damage to clips or bumper.
At the end of the day do what your comfortable doing.
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
04-16-2016, 12:28 PM | #22 |
363
Rep 1,805
The IND DIY THREAD..as I have navigation the yank and pull method isn't a hot idea for me to pursue.. So I would recommend the IND grill removal thread to do so. Hope that makes more sense.
