M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
      04-11-2016, 10:26 PM   #1
Rearview
Drives: F10 M5
How much earl are you burning?
Oil change at 1400. Now 3000 and down 1.25L with warning. Filled back to max level but not over. Dealer says S63tu can burn 1qt every 750-1000 miles for first 6k miles. True dat?
      04-11-2016, 10:57 PM   #2
johnm550
johnm550's Avatar
81
Drives: 2020 M8 Competition Convertibl
I hear a lot of people are having this problem. I have a 2015 M5 Comp. Pkg. with 18,000 miles and never had to top off the oil.
2013 M5
2015 M5 Comp
2018 M5
2022 M8 Comp Conv (Waiting)
      04-12-2016, 12:19 AM   #3
apexlocator
Drives: 2014 M5
Have you checked your intake pipes for oil, particularly the passenger side?
      04-12-2016, 04:53 AM   #4
DingolfingLove
DingolfingLove's Avatar
United Kingdom
41
Drives: 2019 M5 Comp
I did the recommended run-in procedure: alternating revs, engine braking and hard acceleration and mine uses 1l every 2500m. I discussed this with the dealer and 1l of oil every 800 miles is not deemed by BMW as being unusual.
      04-12-2016, 06:25 AM   #5
Rearview
Drives: F10 M5
I have not. How do you do that and what does one do if there is oil in the intake? This thing runs like a scalded ape. I've not noticed any change in performance.
      04-12-2016, 06:51 AM   #6
AGS
AGS's Avatar
501
Drives: 2022 M5 Competition
I'm just over 4,000 miles past the break-in service on my 2016 Comp Pack M5 and I have not had to top up the oil so far.
Like DingolfingLove I follow a regimented break-in procedure I read about from an engine builder that is designed to achieve a tight seal on the rings.
Current: 2022 Donnington Grey M5 Competition, 2014 Anvil WW Jeep Wrangler
Previous: 2019 Donnington Grey M5 Competition, 2016 Silverstone M5 CP, 2013 Monte Carlo Blue M5 CP (ED on 9/1/12), 2009 Carbon Black M5, 2006 Silverstone M5, 2003 Sterling Grey M5, 2000 Anthracite 540i6, 1998 Jeep Grand Cherokee 5.9Ltd, 1990 Eagle Talon TSi AWD, 1978 Mazda RX-7
      04-12-2016, 08:27 AM   #7
TrevorM3
3322
Drives: 6.3 AMG
i like op's slang. lol "true dat'?
what yr is your car?
      04-12-2016, 09:08 AM   #8
v3n0m
Drives: 2013 MCB M5
Just FYI. If you only get one low oil warning between oil changes you're probably fine. There isn't a dipstick in the car so when they change the oil they rely on the digital oil level sensor, which apparently isn't 100% accurate. The new filter also hasn't absorbed oil yet so you might go a quart low after things have all settled down.
      04-12-2016, 09:23 AM   #9
NightM
NightM's Avatar
450
Drives: Bmw
1qt every 1200 for me
      04-12-2016, 10:39 AM   #10
Redrckt135
Redrckt135's Avatar
Drives: 16 M5 & 17 X5M
I had to top off twice, car has 8k on it. My SA told me it's completely normal as the car is getting broken in.
      04-12-2016, 12:41 PM   #11
JNoSol
JNoSol's Avatar
Drives: 750 MSPORT & E90M3
Blame it low friction piston rings.
Daily: G12 750 MSPORT Weekend Car: E90 M3
      04-12-2016, 04:56 PM   #12
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Not a drop of top off oil on this M5 (just passed 17k mi), the previous M6GC, or any other S63/N63/N63Tü vehicles with the exception of a 2011 550i, which was a turbo seal failure.
US cars and RoW cars will have different measurements to accommodate false triggers resulting from fuel dilution rather than actual consumption.
      04-12-2016, 05:16 PM   #13
Lerxst M4
Command Sergeant Major of the Army
Lerxst M4's Avatar
Drives: F82 M4
I add a quart of earl about every 2,500 miles. SA gives it to me for free and it's never really been an issue.
Dat ish be true, yo.
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone)
2013 F10 M5 (gone)
2008 E90 M3 (gone)
      04-12-2016, 05:52 PM   #14
GMT234
United Kingdom
28
Drives: M140 mineral grey / oyster
Drove it like I stole it from day 1, 7k miles now, no oil top up yet.
      04-12-2016, 08:58 PM   #15
Rearview
Drives: F10 M5
Dry as a bone
      04-12-2016, 08:59 PM   #16
Mpire
Drives: F10 M5
I have 2014 just reached 20k miles. Not a single drop of oil added.
I think excessive oil burning happens pre 2014 cars.
      04-12-2016, 08:59 PM   #17
Rearview
Drives: F10 M5
Hey Trevor, 2013. Purchased with 1700 miles on it
      04-12-2016, 09:01 PM   #18
Rearview
Drives: F10 M5
That would make me feel at least a little better
      04-12-2016, 09:04 PM   #19
Rearview
Drives: F10 M5
Jus don wan no disrespeckin my ngin.
      04-12-2016, 11:05 PM   #20
Maverick997
Maverick997's Avatar
49
Drives: 2014 M5 Black Saphire Metalic
25k on a 2014....not added anything between oil changes...
Other toys
'07-997 Turbo....EVOMS 580..AWE exhaust...champion intercoolers..champion springs.
'91-964 Turbo K27 Hf turbo...Techart Exhaust...etc, etc
      04-13-2016, 12:20 AM   #21
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
On the S63TU, the electronic measurements are far more accurate than a dipstick could possibly be. I was apprehensive about BMW following Porsche in eliminating it, but knowing now how, when, where, and why oil is flowing through the system makes complete sense. When the oil is cold and thick, if there is a 2.5bar or more pressure differential between the intake and exit ports of the oil filter, the filter is bypassed to provide adequate lubrication. Also with oil temps below 100'C, the oil cooler is bypassed as well. So there can be significant amounts sitting in situ, until the DME's determine its needed. Hence why the capacity was increased by 1L on paper to account for these temporary fluctuations. After a fresh change, the system will flow completely momentarily, fill the cooler, but will bypass the filter rather quickly which can trigger the QLT to issue faults/CCM's (overfill at first, then low level once all the passages are filled).
      04-13-2016, 03:02 AM   #22
DingolfingLove
United Kingdom
41
I would have been banned @ 10 miles if i'd done that!
m5post
