BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
EXXEL Distributions
      07-18-2016, 06:19 PM   #1
K_style
Drives: E92 M3
Minor misfire after spark plug change
After replacing spark plugs (NGK LKR8AP) on my E92 M3, there has been minor misfiring here there that bothers me crazy.
I applied minimum amount of anti seize and torqued to proper spec however I did not regap because it is dual prong plugs.
Does anyone have any possible cause of this?
      07-18-2016, 10:45 PM   #2
W Cole
Drives: 2009 M3
Did you check the codes? If it's throwing one then it will tell you what cylinder(s). I never gap the plugs just eyeball them and make sure nothing look out of whack. Maybe one of the plugs has an issue? I would think any anti seize should burn off pretty easily.
      07-19-2016, 09:36 AM   #3
K_style
Drives: E92 M3
No there has been no code except the very first time when I forgot to plug #3 cylinder coils but fixed that right after.
      07-19-2016, 12:49 PM   #4
AWTT335i
11
Drives: E90 M3
I would try removing the anti-seize. It will skew your torque reading as well as potentially interfere with the plug ground.
Not saying that is definitely the root cause of your issue, but its certainly a variable i would eliminate.
      07-19-2016, 03:22 PM   #5
K_style
Drives: E92 M3
So no anti seize at all?
      07-19-2016, 04:32 PM   #6
W Cole
Drives: 2009 M3
I never use any. Maybe if this car had a 100k mile interval..
      07-19-2016, 05:34 PM   #7
K_style
Drives: E92 M3
I will try that... hope this fixes it.. Anyone else have other ideas?
      07-19-2016, 06:02 PM   #8
squartus
Drives: 2010 E92 M3 6MT
2010 E92 BMW M3  [10.00]
Also says in manual not to use anti seize, never suppose to apply any or any lock tight on bolts that your torquing "unless called for" as it drastically changes the torque pressure. Think its around 30% increased torque when the bolt is lubed up like that.
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc
m3post
