07-20-2016, 09:53 PM | #1 |
Rep 36
Servicing/Maintenance Perth
Hi Guys,
Just picked up a 2008 Jerez Black DCT M3. Just wondering who you would recommend for Servicing/Maintenance around Perth? Also I will be looking a getting it detailed in the future so would appreciate any recommendations on where to get this done also? Cheers |
07-20-2016, 11:52 PM | #2 | |
Rep 1,464
Drives: BMW X5M Comp
I'm sure a lot of the locals on this post can suggest a good detailer who does paint correction |
07-21-2016, 03:40 AM | #3 |
Rep 621
Drives: 2008 Jerez Black E92 M3
I use and recommend Josh at Galvsport (Msport) to do all scheduled maintenance and repairs http://www.galvsport.com/
I have used and recommend Des at AutoFx for paint correction work https://www.facebook.com/AutoFXWA/?fref=ts
Jerez Black 2008 6MT with Borla Atak Exhaust/ M3 World X Pipe and Test Pipes/ aFe Pro Stage 2 Intake / 19" Advan DZ-DF Forged Wheels wrapped in ContiSport Contact 5P 245/35/19 Fronts & 285/30/19 Rears/ KW Var 3 Coilovers / BPM Sports Stage 2 Tuned/ VAC Rod Bearing Replacement / Throttle Body Actuator Gear Set
07-21-2016, 08:10 PM | #5 |
61
Rep 377
i use http://www.bmtechniks.com.au
these guys are really good and stand behind the work they do. the owner andrew will come out and explain everything to you. |
07-22-2016, 12:00 AM | #6 |
90
Rep 389
Drives: 2009 E90 M3 AlpineWeiss 3
2dr or 4dr? I've seen a clean E90 jerez cruising around my area lately
I use Jesse @ EuroTechnik for my M3 as it's close to home, have also used Josh @ Galvsport for my project car. Have not used Des @ AutoFX but heard raving reviews for detailing. Also http://www.manndetailing.com/ are supposed to be excellent. |
07-22-2016, 08:21 AM | #7 |
Rep 287
Congrats and welcome to the Jerez club.
When you get a moment flick through my thread. Its also Jerez black detailed by "Finest 1 Detailing" Great bloke that really knows his stuff. Haris' mobile is 0439 932 626, drop him a text and mention my name and car. http://www.m3post.com/forums/showthread.php?t=896342 |
07-28-2016, 09:03 AM | #8 | |
Rep 36
07-28-2016, 07:16 PM | #9 |
Rep 1,107
I have the BMR H8 LEDs in mine and am happy with them. They are certainly great value, are bright enough to keep me happy and look a lot better than stock. I gather the LUX versions are hugely popular and they are brighter if you have them side-by-side with the BMR ones. At extra cost.
http://www.bmraw.com/lighting-1/ |
07-29-2016, 07:36 PM | #11 |
Rep 283
I've got the bmr ones on my e87. Find that the outer rings not as bright as the inner.
Used bm techniks at Bayswater too. Used to go to Ramp automotive at malaga but mate and I both had problems with them. |
07-30-2016, 06:07 PM | #13 | |
Rep 2,664
Drives: Goggomobil
F86 X6///
07-31-2016, 03:27 AM | #14 | |
Rep 1,464
The LED shines down the plastic light pipe as does the 35 watt lamp to give a white effect instead of a yellow (3000K) input. The limitations are in the optics of the OE light rings and getting a 10 watt LED to give the same light output as a 35 watt halogen bulb. These aftermarket systems are better than OE but still don't come close to a full ring replacement with multiple LEDs around the ring rather than a conductive light path, but as always cost comes into it. The better quality the LED and heatsink the better the result. The LEDs have a long service life over a traditional halogen lamp but will fail if the thermal bonding between the LED and heatsink is not a good design. This is the primary cause of LED failure, it needs proper heatsinking or it will fail. The alternative is a xenon kit with inverters which have a very high power pure white (6000K) xenon lamp shining into the light pipe. The side effects of these kits though are yellowing of the internal plastics due to heat and UV emissions, poor sealing of the access caps and failure of the inverters. They are a good short term solution but in the end will cause yellowing of the internal plastics if they don't fail in the meantime. The ultimate is the OSS design concept which replaces the rings and is expensive, but looks amazing. One of our local members has experience doing this, but its a big job. |
08-06-2016, 01:43 AM | #15 |
Rep 206
Drives: 2021 G80 Competition
Des from Auto FX and Ryan from Kustom Koncepts for detailing. Also one of my Lux led keeps flickering, installed them 2-3 years ago.
2019 F87 M2 Competition 2021 G80 M3 Competition (sold) 2010 E90 M3 Competition (sold) 1995 E36 M3 (sold) |
08-06-2016, 10:43 PM | #16 |
Rep 36
Picked up some Lux H8 160's and fitted during the week. Big improvement over the OEM look! The only think is they don't fade out when going off, they flicker?
08-30-2016, 09:37 AM | #17 |
9
Rep 41
Drives: 2011 E90 M3 Pure
I have Lux V5 adjustable and have them up full brightness and never had an issue.......
Other divers think I have the high beam on sometimes though |
