R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > Sponsor M3/M4 Project Cars Showcase
Closed Thread
      08-01-2016, 11:29 AM   #1
Carlos@TAG
Drives: M Cinco
Ohlins Road & Track Coilovers // TAG Motorsports
The owner of this Silverstone M4 did not want to lower his car in his pursuit of improved handling. A lot of coilover options on the market are designed around the assumption that owners will want to decrease ride height, this means that they often cannot be set close to factory ride height or that they would not feel right if set that high. The Ohlins Road & Track is designed so that ride height can be set near stock if desired and they work beautifully well in this configuration. In this case, the owner also chose not to change the front to rear rake that is present on the factory suspension setup so this really is the ultimate OEM+ setup in our opinion: factory suspension geometry with full travel and plenty of ground clearance but with significantly firmer springs and much better damping! The easily-accessible compression/rebound adjustment knobs gave us the ability to fine tune firmness to the customer's taste more quickly than is possible with other coilover designs.
What do you think? Contact us with any questions or if you would like to discuss the many suspension upgrade options we have for your M3 or M4 today!
domino_z1239.50
      08-01-2016, 12:04 PM   #2
RocketBoots
RocketBoots's Avatar
Drives: Horse Drawn Carriage
Did this have a 'missing nut', as was mentioned in another thread? And you guys had to scrounge up a nut or something?
Also, it looks like the customer is running OEM size tires. If one were to move the rear tires to the front, and get 295/35's in the rear, do you think that would require spacers? I believe another person reported some issues, and required spacers for wider tires.
Thanks!
      08-01-2016, 12:58 PM   #3
WoohooSoCal
WoohooSoCal's Avatar
237
Drives: 2015 M4 SS II / SS
Thanks for featuring my car, Neema and Gabe. I'm embarrassed it was so filthy, especially the wheels, when I dropped it off.
Yes, RocketBoots , I'm running stock tire sizes. I'll be staying at stock ride height even after I decide on new wheels. All of the hardware was included. I checked before I dropped it off at TAG.
I wanted a slightly aggressive street setup over stock as I may only track my car once, at which time I can dial it up.
Impressions after 3 days:
- Flatter on turns and hard braking. Turn in is sharper.
- The rear doesn't wiggle-wobble under hard acceleration. It hooks up in a straight line and flat, a hard acceleration in the middle of a turn = no wallowing.
- Rebound and compression are improved as I can feel the backside of bumps - no float. I believe I am in the lower 1/3 of the stiffness scale for adjustment of this set and the improvement over stock is obvious. I will go a couple of clicks stiffer for a test this week. The car is comfortable and handling to my preference.
- I have active sound coded out and I can hear slightly more road noise with this setup. Not an issue just an observation with the radio off.
Gabe, Neema, Sean, and Alex at TAG are great. They spent a lot of time with me talking suspension, wheels, exhausts, and tunes...I recommend them and will return.
      08-01-2016, 02:30 PM   #4
RocketBoots
haha, I didn't even notice the wheels... but now that you mention it, they ARE filthy
Thanks for the feedback. Didn't realize that was your car I saw your review. Good to hear yours wasn't missing any nuts or bolts.
      08-01-2016, 03:14 PM   #5
Carlos@TAG
Drives: M Cinco
To clarify, the top nut is re-used from factory as the instructions indicate. I'm not sure why the other car on this forum had issues with the nut not fitting but the factory top nut went back onto this car without any issues.
      08-23-2016, 05:23 PM   #6
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
I think that looks perfect, is the car set up on the max height or lowest?
730d/Z4C
      08-24-2016, 11:27 AM   #7
Carlos@TAG
Drives: M Cinco
This customer wanted to stay as close to stock ride height as possible, there's plenty of room to go lower than what you see here.
Wills28656.00
      08-24-2016, 12:14 PM   #8
WoohooSoCal
237
One month in and still going strong, no issues, strange sounds, no adjustments needed....bliss. Highly recommended.
Thanks again TAG.
      08-24-2016, 07:52 PM   #9
S65V8
*_*
Drives: ...
Doesn't this image show you've lowered it in front pretty much as far as it can go?
      08-24-2016, 09:07 PM   #10
kitesurfer
kitesurfer's Avatar
543
Drives: Round n' Round
Looking at this pics you posted the front spring perch looks almost to the bottom, my guess 3/8" more adjustment left
Rear spring perche look the same about 3/8" left
how is this plenty of room to go lower?
      08-24-2016, 11:56 PM   #11
x.shell
x.shell's Avatar
6579
Drives: ▋ ▉▉
As far as the front strut assembly goes, I believe the Ohlins RT adjusts it's ride height with the lower collar in conjunction with the spring perch. However, the spring perch is most likely used to set the spring preload while the lower collar is mostly used to set ride height. This allows the shock to use it's full compression stroke.
That being said, it does look like the shock will go down into the collar about an inch more... give or take.
The rear is your typical BMW coilover perch. It doesn't look like it'll go down much further.
It's also possible that the pictures were taken before adjusting ride height.
      08-25-2016, 05:02 AM   #12
S65V8
*_*
Drives: ...
I hope so, but regardless, both collars show the car is almost at its lowest setting. It would be great if I was wrong and there's significant room to drop the car on these amazing coilovers.
      08-25-2016, 03:35 PM   #13
Carlos@TAG
Drives: M Cinco
If your primary goal is to lower your car, other kits on the market can go lower. This option is best for people who want a moderate drop or who want to stay close to stock but who are looking for improved agility, stability, body control, etc. The Road & Track does an incredible job of soaking up bumps, this is partly because it retains good suspension travel, partly because it maintains very good suspension geometry, and partly because of Ohlins' very nice dampers.
There is room to go lower than what you see here but not as low as some of the other popular options. The recommended ride height is about 1/2" below factory height and there is some room to go higher or lower than recommended as with all coilovers.
ddk632585.00
      08-25-2016, 04:51 PM   #14
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
I think it's the perfect set up for those that want the benefits of a coilover setup whilst still maintaining OEM style clearance, the side on picture looks very OEM+
730d/Z4C
      08-31-2016, 07:37 PM   #15
Gabe@TAG
731
Drives: F80 M3 6MT
100% agree.
      08-31-2016, 09:48 PM   #16
S65V8
*_*
Drives: ...
Thanks for confirming the ride height adjustment of the coils is for those looking for OEM like ride height clearance, but with just amazing coilover performance.
      02-19-2017, 03:34 PM   #17
ddk632
Chief Senior Executive Managing VP of Orange Sales
ddk632's Avatar
Drives: 17 BMW F87 M2 6MT MG HBDGR !
This is awesome! Coming from motorcycles, I have 100% trust in Ohlins suspension over anything else. Nice to see there are good options out there without sacrificing daily-drivability of the car.
      02-19-2017, 10:08 PM   #18
domino_z
1240
Drives: F-Pace SVR
i had ohlins dfv's on my evo x - they were too stiff for street use, but in the hills/canyons the dampening at speed was spot on
i'd love to drive an f80 with a set of these
anyone looking at these with main priority of lowering is in the wrong thread
      04-01-2017, 07:21 AM   #19
katzndogs
Drives: '16 M3 6MT
PM for a set shipped to 03801!
Arcades8174.00
      04-04-2017, 04:51 PM   #20
Gabe@TAG
731
Drives: F80 M3 6MT
PM coming your way!
      04-04-2017, 05:27 PM   #21
Fast4d
Drives: 325
stock ride height possible? then it's ohlins for sure when the time comes....
I also enjoy ohlins on my bikes.
      06-22-2017, 10:56 AM   #22
Motodude310
Motodude310's Avatar
51
Drives: 2011 GTI
I currently have the road and track coilovers on my GTI, and they're great for the street. If you're looking to track more regularly you'd probably want a more aggressive setup.
The down side is that they require periodic rebuilds. I believe Ohlins states every 15k miles, which is a total pain in the ass, and unrealistic for a street car. Is that the case with this setup too?
PS: The rebuild is $200 per corner.
Closed Thread
f80post
