08-24-2016, 01:22 PM | #1 |
Advansolosis
218
Rep 1,448
ESS VT-2 Kit "Supercharger Whine" Is this normal?
Hi All,
Just wondering if this whine on the supercharger is normal or is this normal for the ESS VT2 kits? I ended up changing the supercharger pulley and belt because i thought it was abnormal. Thoughts? UPDATE, BETTER VIDEO BELOW
2011 E90 M3, ESS VT2-650, 2015 GL550 Last edited by advans; 08-26-2016 at 10:44 AM.. |
08-24-2016, 02:34 PM | #2 |
997.1TT
1004
Rep 1,672
video quality was subpar but I will say mine doesn't whine. it sounds like shit but there is no whine I can speak of. Mine sounds like a handful of rocks being shaken in a tin can which is normal for these Vortech superchargers.
08-24-2016, 02:43 PM | #3 |
124
Rep 386
Drives: '07 328xic '11.0 M3 DCT
That would have to be one of the worst things I have ever heard about these superchargers........
2011.0 E92 M3 M-DCT ZCP ZTP ZPP Black Wrapped Jerez Black + 2007 E92 328xic 6MT 2007 YZF-R6 + 2001 Honda Shadow ACE 1989 RS Camaro - HO 350, Dynomax headers, flowmaster AT exhaust, 4.56 gears 2015 STI Launch Edition |
08-24-2016, 04:15 PM | #4 | |
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
460
Rep 2,002
Drives: 2011 E92 M3 DCT/ESS 625 kit
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625 2016 F15 X5 Msport 35i |
08-24-2016, 05:12 PM | #5 | |
Advansolosis
218
Rep 1,448
Rod bearings? wait. I think the ticking noise is the rain hahaha. Do you hear when the engine revs up, it has this weird high pitch tone.
2011 E90 M3, ESS VT2-650, 2015 GL550 |
08-24-2016, 05:37 PM | #6 |
460
Rep 2,002
lol. No bearings in the super charger. All I hear about is rod bearing on this forum. It's staring to really scare me know. I should just get mine done for peace of mind.
08-24-2016, 09:00 PM | #7 |
Rep 855
Has the whine always been there (newly installed)? Do you only hear it under acceleration or can you just rev it? How is the oil level?
-- 08 JB e92 6MT ///M3 ESS VT2-625 --
08-24-2016, 09:59 PM | #8 | |
Advansolosis
218
Rep 1,448
I ended up changing he superdriver pulley and belts and also have changed out oil too, so I have no idea what's wrong or even if there is anything that is wrong.
08-25-2016, 06:49 PM | #9 |
Rep 70
Check to see if they tie wrapped any of the hoses to the strut tower bars or if anything else is rubbing on the side of the engine bay. I had a whine in the cabin when I first installed my VT1. I used a mechanics stethoscope to track it down. The installer had tie wrapped one of the lines from the side of the manifold to the strut brace bar and it resonated into the cabin as a difficult to place whine. I cut the tie wrap, problem solved. Alternatively, I would highly recommend buying a mechanic's stethoscope and just touching it to different parts of the engine/supercharger to track the source. I have found several sources of noise using it and they are a cheap investment.
08-25-2016, 08:24 PM | #10 |
Rep 1,385
Sounds like you need to have the supercharger serviced, Are you sure you have the correct amount of oil and check for shavings.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car Last edited by Properstyle; 08-25-2016 at 08:37 PM.. |
08-26-2016, 10:46 AM | #11 |
Advansolosis
218
Rep 1,448
Thanks, I just had it serviced. They flushed the supercharger and added 1 of the 4oz bottles as recommended by Vortech
08-26-2016, 10:46 AM | #12 | |
Advansolosis
218
Rep 1,448
08-26-2016, 03:48 PM | #13 |
Rep 855
I hear the whine through the entire video and really hear it at the end. It sounds as if you have solid subframe/diff bushings. It is not normal for that much whine but its hard to tell with a video. The inlet pipe going into the vortec comes very close to the chassis.. could it be resting on it? I really think you should have someone who is familiar with this kit have a listen in person.
Sorry i can't be more help to you buddy!
08-26-2016, 04:28 PM | #14 | |
Advansolosis
218
Rep 1,448
01-09-2023, 01:49 PM | #15 |
Όλα ρόδες
760
Rep 560
Drives: BMW
Garage List 2004 e46 M3 Convert ... [7.50]
2023 M4 CSL [8.17] 2007 E86 M Coupe [0.00] 2008 e93 M3 [0.00] 2019 M2 Competition [9.67] 2017 f48 X1 xdrive 25d [6.00] |
I am resurrecting this thread because i am getting the same whine from a new to me ess vt1 equipped e93. Hoping that after six years the collective experience over here might point me to the right direction of dealing with this assuming that this whine is not normal.
Anyone? |
