08-25-2016, 06:57 PM | #1 |
Rep 3
2008 E90 S65 Rod Bearing - 74k
Just adding another experience to the library of threads. Had my rod bearing job done as "preventative maintenance" at a little under 74k miles. Don't know much about the history of the car. Went with the BE Bearings and had the work done at Ace Performance Systems in MA. Tops are shown and match the lowers on the right which were all ok as was the crank.
08-25-2016, 08:16 PM | #3 |
Rep 1,385
These as worn as are they are look great for having even wear. Going with the be bearings should help out a lot opening up your clearance.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
08-25-2016, 08:55 PM | #4 |
Rep 3
Just stock for the bolts.
Definitely not the worst out there but glad I did it now. |
08-25-2016, 09:09 PM | #5 |
is fast cars
391
Rep 2,137
Thanks for sharing the photo. Hope that's what mine look like!
Daddy's Rocket Sled!
Clarkson: "It is... pretty much perfect... Why don't I have one of these cars?" Harris: "The saloon is definitely the M3 of choice." |
kb9uwu309.00 |
