08-29-2016, 07:54 PM | #1 |
Rep 101
DCT Gear Noise
New to the E90 M3 coming from an E46 M3 Im used to a lot of noises coming from that but have researched this one for the E90 and read multiple times its normal but never seen someone post a video of the situation.
Check out the video below, is that noise normal hearing the gears change? I test drove another E92 before I got this 19k miles and it did same noise, my friends E92 with DCT GTS tune doesnt make the noise tho, at least i didnt hear being passenger.. Maybe the tune fixes it? Video: https://vid.me/HaZg |
08-29-2016, 09:14 PM | #2 |
Rep 545
Shifting from 1st to Reverse will produce some noise because the hydraulic clutches have a small amount of drag with the engine running. This is similar to (less than) an automatic transmission vehicle with a torque converter.
As you change gear selection (1st to Rev) there is a small amount of clearance between all of the parts from the DCT input shaft to the rear wheel mounting flange (rear hub) where the parking or service brake is holding the vehicle. Those small amounts of clearance between gears and connections will allow a small movement of the driveshaft and create the noise. More clearance or play between parts equals more noise. With the vehicle on a lift you can observe the driveshaft movement, but the clearance or play cause can be located in several places. There is a chance that your drive train has a little too much play. With out sitting in your car and/or checking on a lift in the air we will have a hard time deciding if this is normal or excessive. Your video is helpful, but really depends on the microphone and placement. If you can go back to your friends car and sit in the driver seat while selecting gears, you will hear the noise...maybe less or maybe more. I do not believe that a DCT software update or tune will change your vehicles sound. This video will help you with a view of the movement. This is NOT a BMW and uses different parts. The driveshaft movement is similar though. You could video this on your car by placing your camera in record mode with a drop light under the differential input flange while you operate the shift lever. DO NOT get under the vehicle with the engine running. A skilled professional could do this on a lift for you to verify the problem. This is not just a "wild ass guess" on my part. I taught automotive classes for 41+ years and specifically Automatic Transmissions, Manual Transmission, and Powertrain classes at the community college level for 37 years. |
08-30-2016, 08:50 AM | #3 | |
Rep 101
08-30-2016, 09:15 AM | #4 |
63372
Rep 24,674
Your DCT noise is not normal , I don't hear this with my DCT .
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
08-30-2016, 10:00 AM | #7 | |
63372
Rep 24,674
If you say it's normal and all ///M's do ...Why your question ?
08-30-2016, 10:04 AM | #8 | ||
Rep 101
Im assuming it could be normal because ive heard it in other cars and bmw stated in manual but then I hear others saying you dont hear anything. Maybe you dont hear because of the exhaust? Haha! Kind of wondering |
09-02-2016, 12:41 PM | #10 |
Rep 1,326
normal. i wouldn't worry about it
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
09-02-2016, 07:20 PM | #11 |
11586
Rep 12,726
my car did this and it was quieter. now that i have solid diff/subframe bushings, it is a lot more pronounced. i'm ok with it.
Instagram; @roastbeefmike
09-02-2016, 07:21 PM | #12 |
Stop the hate, get a V8
3850
Rep 8,625
The owner's manual literally says "because this is a motorsports vehicle, it will make more noise and be less smooth than other cars".
In other words: normal.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
09-02-2016, 08:02 PM | #15 | |
Rep 101
