BMW X5 and X6 Forum 2014-Current
Go Back   BMW X5 and X6 Forum (F15/F16) > BMW X5 (F15) and BMW X6 (F16) Forum > Vendors Classifieds
      09-01-2016, 02:10 PM   #1
carlos@velosdesignwerks
Drives: BMW M4
BMW F8X X5M & X6M | Labor Day Weekend Promotion | Velos Personal Tuner
Dear Members,
We can all share that most of our day is dedicated to working and driving.What better way to celebrate Labor Day than in the driver's seat of your M. We are running a Labor Day Promotion on our Personal Tuner Module for the X5M/X6M with a savings up to 40% off.
Our Personal Tuner upgrade includes simple step by step instructions to our plug and play solution that increases power output by 97 HP and 108 lb ft torque. Peak gains are in the mid range where you spend the majority of your time driving. Having done testing in both favorable and unfavorable conditions, I bring you the results from the "unfavorable" runs with temperatures exceeding 105 degrees Fahrenheit in the dyno room. Our engineering team has spent countless amount of hours in R&D to provide a reliable tune while keeping all safety parameters intact. The Velos Designwerks Personal Tuner Module is must for any "M" enthusiast looking to reliably augment their vehicle's power.
Send in your request via PM
Phone 786-401-6520 or
Email Albert@velosdesignwerks.com.
Retail Info;
http://www.velosdesignwerks.com/prod...software-2015/
Don't Miss Out On Our Early Bird Limited Stock Available Labor Day Week
  • +108 TQ
  • + 97 HP
  • Improved Peak Gains
  • More linear power curve
  • 100% Plug and Play (no cutting or splicing
  • 100% Reversible
  • bypass plug included
Importance of RPM Integration
This personal tuner is engineered to use RPM calibrated tuning allowing for a smoother power curve that does not aggressively fall off towards red line.
What does Plug & Play mean?
This means there is no need to cut or splice into the factory BMW wiring loom (harness). The Velos Personal Tuner uses factory connectors to guarantee a sure connection without any issues. The unit can also be removed in a manner of minutes requiring basic tools.
Quality
The build quality of the module, electronic boards and loom is of the highest quality components available. Our Personal Tuner uses factory connectors as well. This assists in ensuring no Check Engine Lights or other warning lights. Built in Germany, assembled and Tuned in North America.
Adjustability
The personal tuner comes with preset calibrations resulting in a power curve that delivers constant and more importantly reliable power through the entire RPM band.
What is the by pass plug?
This allows you to go back to factory settings in a manner of minutes by installing our by pass plug and removing the module. Keep in mind a complete uninstall will only take roughly 30 minutes
Dyno conditions.
Albert Guerra
Velos Designwerks
Office 786-401-6520
Cell/Text. 305-439-7933
Tags
bmw f85 x5m, bmw f86 x6m, velos designwerks, velos tune
