09-02-2016, 09:26 AM | #1 |
Rep 54
Enigne Serial Number?????
Just got a 35k miles locked up S65 from one of the local guy.
Planning to use it as spare parts. The rod bearings look horrible for a 35k miles engine. Also, it has sleeves. The factory set up doesn't come sleeves, right?? Can anyone confirm? Anyone know how to find out more information of the engine with just the serial number stamped on the engine? Thanks in advance! |
09-02-2016, 10:12 AM | #2 |
BimmerPost Supporting Vendor
1439
Rep 1,614
Another sleeved block bites the dust. I can't understand the attraction of sleeved s65 blocks to people for this knowing it will weaken the block and knowing so many of them have already failed.
No, the s65 doesn't come with sleeves. This is usually done by people trying to build high horsepower, low compression, supercharged motors or track cars that can change out engines when one fails. The motor has already been rebuilt at least once. If the rod bearings are toast, most likely the crank is too. If you're buying it for parts, you should negotiate a price that assumes the heads are the only usable parts. |
09-02-2016, 10:27 AM | #3 |
1439
Rep 1,614
Can you post pictures of the crank, rods, and bearings? That could show some important information about what type of motor this was or wasn't built into.
09-02-2016, 10:35 AM | #4 | |
Stop the hate, get a V8
3850
Rep 8,625
I suppose if you could get the original car's VIN you could get the service history from a dealership.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
09-02-2016, 03:50 PM | #6 |
Rep 54
09-02-2016, 04:41 PM | #7 |
3850
Rep 8,625
Fair enough, and he's not obligated to, I just hope that was factored into the price.
09-05-2016, 12:06 PM | #8 |
Grease Monkey
295
Rep 2,646
Drives: 2011 E90 M3,1994 Euro E36 M3/4
Looking at the internal pictures you posted I see factory rods and what appears to be factory pistons. I would highly doubt anyone would go through the work of sleeving a block without upgrading rods and pistons, not to mention factory pistons don't work with steel sleeves.
Edit: Upon a closer look at the photos, you can't see sleeves at the bottom of the bore....... To install sleeves the factory bores will be overbored and the sleeves pressed in so you would see the sleeves looking at the pistons from the bottom. |
MilehighM3915.00 |
09-05-2016, 04:54 PM | #9 |
3751
Rep 2,907
Drives: 2011 E93 M3
Looks like a typical stock block that hydrolocked. Bearings in that picture look typical for these engines. Doesn't look to be sleeved. You might be able to salvage the block but assume the bore with the bent rod has been damaged. It will likely require boring or sleeving later. The crank might be ok. Though the seller might not be obligated to disclose the VIN, I would question the honesty of a seller who won't.
09-10-2016, 10:14 AM | #10 |
Rep 8,076
Drives: 11 E90 M3 Individual
I thought the last 7 of VIN (or something) was stamped on the back of the engine block? I know my S54 block had a S/N on it but never looked for a VIN since I the seller gave me the history.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
09-10-2016, 01:28 PM | #11 | |
Rep 201
Unless sold at near scrap value, I wouldn't do a deal with a guy who wouldn't share this basic information which, at a minimum, would be necessary to determine if the damn thing was stolen. |
