09-05-2016, 07:16 PM | #1 |
Rep 3,140
Drives: 2014 M5 6MT
Rod Bearings at 89k Miles
2008 E90 M3, 89k miles of mixed daily and track use. TWS 10W60 it's whole life, I am the second owner.
You can see the copper is showing in all of the upper bearings. Crankshaft was smooth and didn't show any signs of wear. All of the crank journals measured out to OE specs. Replaced the bearings with VAC motorsports coated bearings and new OE bolts.
2014 M5 6MT
09-05-2016, 07:48 PM | #2 |
4-6-8
234
Rep 990
Yowza! Good catch!
M3 E46 PY/Black
S2000 AP2 GPW/Tan |
Solo_M_Tech1687.50 |
09-05-2016, 07:52 PM | #3 |
63375
Rep 24,674
It was time...
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
09-05-2016, 07:55 PM | #4 |
F15 daddymobile
2350
Rep 3,510
thanks for sharing and posting pics!
09-05-2016, 09:20 PM | #6 | |
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
09-06-2016, 08:59 AM | #8 |
420
Rep 1,678
Drives: 2011 MCB E92 M3
Talk about running on borrowed time. Glad you got them done.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
09-06-2016, 10:44 AM | #10 |
Rep 1,385
ouch those bad boys look toasted. i just changed mine at 91k and they looked nearly new
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
09-06-2016, 10:49 AM | #11 |
Rep 1,246
Drives: E92 M3
09-06-2016, 11:14 AM | #12 | |
Rep 3,140
Drives: 2014 M5 6MT
2014 M5 6MT
09-06-2016, 11:43 AM | #13 |
Rep 615
Drives: E92 M3 6MT Space/Black
09-06-2016, 08:28 PM | #14 |
Rep 3,341
They had a good life, RIP.
09-07-2016, 10:53 AM | #15 |
121
Rep 1,775
crazy... ive always been curious about this rod bearing thing.... if you replace your RBs at 89k miles how much more life can we expect out of this motor? i mean, what about piston rings? when will those begin to have blow by? i know it may be a silly question but sometimes i feel like just keeping my m3 and then other days i want to sell it...
2014 M5 Comp Package.
09-07-2016, 11:48 AM | #16 |
5234
Rep 10,616
Have not read much about any other internal engine problems. There are many posts about rod bearings. Just a couple about failed main bearings, a couple about vanos issues, and a couple about broken valve springs. Have yet to see one on failing piston rings. I have had my 08 since January of 2011 and dont have any plans to get rid of it. I did the rod bearings in 2014 when the warranty expired.
If you are a worrier or stressed about car problems and can afford it, buy cars under warranty and sell them when coverage lapses. If you cant afford that, find a more reliable or cheaper to maintain car. Enjoy your car if you are a car enthusiast, or find a car you can enjoy. |
SYT_Shadow11490.00 |
09-07-2016, 11:52 AM | #17 |
5234
Rep 10,616
Turbo tuning is much more challenging than centrifugal supercharger tuning. Hope he can get it tuned. Supposedly Gintani has done it. Mike Benvo might be able to since he was involved with the Harrop kit and a positive displacement supercharger tune is also more complex than a centrifugal tune. Or he could go standalone but that makes inspection an issue in many states for a late model car.
09-09-2016, 06:47 AM | #18 |
Rep 3,303
Replacing bearings does not fix problem. Because of certain financial interests everyone hurries the myriad of reports of members who have had blow bearings AFYER replacing them with B/E, VAC, etc. In fact, on many of those they blew faster the second time.
Cheers, e46e92
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
09-09-2016, 09:34 AM | #19 |
Captain Fatbelly
1423
Rep 1,994
Having just pulled VAC's after 13k hard miles and finding them perfect I have to disagree. We've yet to see a single member have a bearing failure with BE or VAC. I mistakenly believed mine had failed awhile back but when they were removed they were pristine and are going right back in the new engine. Other than squartus who had a failure with wpc oem's I've never seen a failure reported with aftermarket bearings. Got any links?
09-09-2016, 10:38 AM | #20 | ||
829
Rep 3,387
09-09-2016, 12:48 PM | #21 | |
5234
Rep 10,616
Also gross speculation on replaced bearing failures. "myriad reports?" "many" motors with replaced bearings blew faster the second time? |
