09-10-2016, 02:38 PM | #1 |
Rep 269
Gauge Setup for SC
I was hoping that someone could help me with a few questions regarding setting up dial gauges in my car.
I plan on running AFR, Boost and Oil pressure. Manufacturer will be autometer because I have boost and AFR left over from a past car. Question 1: for AFR where did you place the bug? Or does it really matter where if you are running cat less? I'm assuming anywhere along the test pipe probably close the the rear o2 pending clearance. Please correct me if my assumption is wrong. Question 2: Does anyone have a DIY for an oil pressure gauge setup? I lost on this one. Question 3: is there a better option of gauge then oil pressure in your opinion Question 4: I'm clear on boost pressure, but does anyone have experience in where to splice for the most accurate and visually clean? In theory it should not matter but figured I ask. Thanks in advance for any help given! |
09-11-2016, 02:01 AM | #2 |
Rep 1,246
Drives: E92 M3
Awron.
09-11-2016, 02:30 AM | #3 |
997.1TT
1004
Rep 1,672
I would personally just go with the acm p3. Factory look easy install and has every feature you want and then some. That's what I'll be running soon. Autometer gauges just seem a little too aftermarket and always look out of place no matter where you put them.
09-12-2016, 12:25 PM | #4 |
PAZUZU
545
Rep 2,058
Drives: '15 M4
couldn't have said it better. just get the adapters and use the two extra connections for the oil pressure. All gauges in one at a pretty economical package. i love the single gauges but they are not easy to mount and connect. money no object, i'd go with the awron. that is an amazing gauge setup.
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
09-15-2016, 10:03 AM | #7 |
829
Rep 3,387
2 and 3:
http://www.m3post.com/forums/showthread.php?t=1051091 http://www.m3post.com/forums/showthread.php?t=1101968 I used an AEM 30-4401 pressure gauge set and hooked it up to the P3 to display oil pressure. I realized that I never got around to writing a DIY for it, but it's pretty easy to do. If you want to use an AWRON gauge to display oil pressure, you'll need to get the "compressor II" variant, which increases the price significantly. https://europeanautosource.com/awron...mw-e9x-m3.html Last edited by whats77inaname; 09-15-2016 at 10:10 AM.. |
Patrón544.50 |
09-15-2016, 12:31 PM | #8 |
21
Rep 313
Here a link to the setup I had a long time ago. http://www.m3post.com/forums/showthread.php?t=845136 My advice would be to not install a boost or AFR gauge anywhere except at eye level -- it is simply not safe to be looking down to monitor boost or AFR when you are WOT on a supercharged M3.
09-15-2016, 01:21 PM | #9 |
997.1TT
1004
Rep 1,672
Just looked into the Awron gauge today. damn it's expensive but I think I may have to go that route I stead of the P3. Can anyone comment on how accurate the hp and tq readings are?
09-15-2016, 01:31 PM | #10 | |
BimmerPost Supporting Vendor
2921
Rep 21,727
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
09-17-2016, 12:51 AM | #12 |
997.1TT
1004
Rep 1,672
I will definitely be looking into the Awron. Seems like a great investment. Ill never have to pay for a dyno run again and it looks fantastic.
Current: 2007 Porsche 911 Turbo Former: ESS Supercharged ///M3 Interlagos Blue ZCP Subscribe to YouTube: https://www.youtube.com/c/Rat3dM Follow me on Instagram: https://www.instagram.com/rat3d_m/ |
