09-11-2016, 05:55 PM | #1 |
I know a thing or 2 about a thing or 2...
3101
Rep 3,470
Drives: E36 M3 Coupe, e39 M5, i3s
Expert advice on exhaust adjustments
Guys,
I installed a Corsa exhaust and can't figure out how to make the adjustments to have the exhaust sit right. I've attached pics to all the points of adjustment, but can't seem to move them. I tried loosing the clamps from the exhaust to the connecting pipes, but no luck. Any help would be appreciated. Thanks.
2019 Imperial Blue Metallic i3s BEV
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) |
09-11-2016, 06:59 PM | #2 |
Rep 1,246
Drives: E92 M3
Loosen up your connecting pipes a little so that they are pressure fit but can still be manipulated. You may need to twist those around a tad to get it to sit properly.
09-11-2016, 07:00 PM | #3 |
Rep 1,246
Drives: E92 M3
PM me if you just want my number, I got some free cycles tonight. I still have my Corsa in my garage.
09-11-2016, 08:40 PM | #4 |
3101
Rep 3,470
Thanks, man. Actually going out of town, but I'll PM you this weekend.
09-11-2016, 09:33 PM | #5 |
11586
Rep 12,728
did you get everything on fully tight? if those pics are just from the mock-up, there might be a bolt or two that aren't aligned right or not in the hole. if the side brackets (behind the rear wheels) aren't both fully seated, i can see this being the cause of the issue.
i'm no expert, but i've swapped exhausts a few times.
Instagram; @roastbeefmike
09-11-2016, 09:38 PM | #6 | |
3101
Rep 3,470
09-11-2016, 10:44 PM | #7 |
Rep 3,482
Try spraying some lube (huehuehue) so they're easier to move.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
09-11-2016, 10:44 PM | #8 |
11586
Rep 12,728
well, that was my initial thought. have you tried loosening everything just to see if you can position the exhaust evenly? if you can't get it where you want it loose, i can't see it happening when its tight.
maybe one of your side hangers is reversed? i think mine might be slightly directional or may have worn biased towards a certain direction.
09-11-2016, 11:11 PM | #9 |
3101
Rep 3,470
Thanks. I'll try that.
09-11-2016, 11:12 PM | #10 | |
3101
Rep 3,470
09-12-2016, 09:55 AM | #11 |
Rep 1,246
Drives: E92 M3
09-14-2016, 05:04 PM | #12 | |
12
Rep 38
This post tells me that you lied straight to my face when you told me the reason you were selling it was that you have an autistic kid and when you went from stock to the CNT the change in sound drove him crazy so you had to get rid of it. It takes a special kind of person to use a handicap kid as part of a lie(if you even have an autistic kid)! From looking at the picture it seems like the car gods are on my side and will hopefully continue to curse your car with issues like this. |
09-14-2016, 05:46 PM | #13 |
Rep 25
When I installed my exhaust, i found that the top middle hanger bent some when removing the stock exhaust. I was able to bend it back by hand, but in one of those pictures it looks like it may be a little out of line.
09-14-2016, 11:50 PM | #14 | |
3101
Rep 3,470
Also, why don't you ask the guy that I bought the Corsa from what I did for him. I drove all the way to Raleigh with a 2 ton jack, jack stands and all my tools in my car. I took off my OEM exhaust, put it on his e93 and then installed the Corsa on my car. I did this so he wouldn't have to pay a shop $300 to remove his exhaust. How many people would have done that? Don't come on here and try to give me a bad name.
2003 Le Mans Blue e39 M5 Dinan S1 1997 Alpine White e36 M3 (the old gal) 2013 Mineral White e92 M3 (sold ) 2014 Carbon Black 650i M-sport (sold) Last edited by Haywood; 09-14-2016 at 11:58 PM.. |
09-16-2016, 12:03 PM | #15 | |
12
Rep 38
You have to understand that when I see that you bought/installed another aftermarket exhaust less than two weeks after you sold your CNT to me it makes me question the reason you gave me for getting rid of it. Especially since the fitment is off. I have heard the Corsa as well as many other exhausts, and while they vary in sound/pitch, they are all louder than stock. I just question how the CNT system bothered your son but the Corsa system with a race x-pipe doesn't?! I didn't make anything up and am not trying to slander anyone. People on this board will come to their own conclusions. I just appreciate the irony of this exhaust not fitting properly on your car after the one I bought from you last month didn't fit properly on my car. |
