M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Engine, Exhaust, Drivetrain Modifications
      09-24-2016, 07:00 PM   #1
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
2007-2016 BMW DCT Clutch Relearn Procedure
Clutch install complete/ fluid filled to capacity
1) Transmission will need to be brought up to 80C temperature before any relearning can start.
-Raise car on a hoist, and run thru each gear for at least 10 seconds (reverse also). This procedure will make sure that the work has been done correctly, while bleeding all the air from the valve body assembly.
2) Touch point learning procedure
-E brake up (locked position)
-Car in Neutral
-Brake pedal needs to be held thru the entire procedure.
-The RPM will “drop down” as the procedure progresses
-After procedure is finished, make sure the car is in “Neutral” position, shut the ignition off.
-“Procedure is successful”
3) Gear Learn Procedure
-Car in Neutral
-3 different levels of shifting will occur with this procedure
4) Torque Curve Reset
-Car in Neutral
-Hold Brake Pedal Down
-Ignition on, but engine off during this procedure
5) Valve body Relearn Procedure
--E brake up (locked position)
-Car in Neutral
-Engine running HOLD ACCELERATOR AT 2000 RPM WHILE HOLDING THE BRAKE PEDAL
-DO THIS PROCEDURE FOR 2 MINUTES
PV1/PV2 RELEARN SUCCESSFUL
The NEW clutch will need to properly be broken in for 500km of normal driving conditions. Absolutely DO NOT break the clutch in on a wheel dyno. Premature wear or clutch burning will occur. There is not warranty for this. Do not do any wide open throttle pulls. The clutch needs to be shifting frequently for proper break in of the clutch plates.
After the 500km break in:
For best clutch performance and longevity, do the following procedures:
-On “M” Series cars make sure the clutch clamping force is turned all the way up, and traction control is OFF. This will allow you go gain 6 complete bars of pressure for proper clutch break in. On Non “M” Series cars make sure the car is in SPORT MODE for proper clutch break in.
-Relearn the clutch touch points
-Relearn the gear box at this time.
Appreciate 7
      09-24-2016, 07:31 PM   #2
Msizzle
Drives: 2013 M6 Coupe
great post
      09-24-2016, 07:55 PM   #3
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
Originally Posted by Msizzle View Post
great post
I hope this clears things up on how to adapt the DCT transmission.
SSP
      09-25-2016, 07:38 AM   #4
panhe
Drives: 2013 BMW M5
Can you do this without a scanner?
      09-25-2016, 11:26 AM   #5
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
Has to be done with BMW scan tool.
SSP
      09-25-2016, 07:37 PM   #6
panhe
Drives: 2013 BMW M5
any specific aftermarket tool?thanks
      09-25-2016, 07:49 PM   #7
allmotor_2000
F10 1/4 WR: 9.9s / 142.5mph 1/2 WR: 175.5mph
1090
Drives: 2018 RS3, 991 Turbo
Rheingold ISTA
Hardware is: http://www.ebay.com/itm/like/2524107...&ul_noapp=true
      09-25-2016, 08:05 PM   #8
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
Originally Posted by allmotor_2000 View Post
Rheingold ISTA
That's interesting, a Chinese source. I guess that's common these days, but I was expecting Germany. Do you know if there is a European source for the same thing?
Just did a quick search, there's a Rheingold USA with no prices posted. The Chinese source is probably price friendly? If one doesn't have the BMW dealership do the install, and if the independent installer doesn't have the tool, this would pay for itself pretty quickly.
      09-25-2016, 08:22 PM   #9
allmotor_2000
1090
Sure - more expensive probably. The SW and license isn't included.
This can do everything the dealer can including the test plans - just that the dealer can get help from the factory on tougher problems.
      09-25-2016, 08:35 PM   #10
Used2be
Perennial PFC
Used2be's Avatar
I did find the Rheingold USA store and the prices are the same, or close. But, they're out of stock at the moment. What is the "SW"(software?) Is the license required to actually do the adjustments?
      09-26-2016, 06:44 PM   #11
Northern X5M
Northern X5M's Avatar
105
Drives: 2014 Tanzanite Blue M5
Kris, is there any reason the dealer would have to reset or reflash the ECM or any modules during this procedure? When the dealership installed your kit they flashed over my tune and reset all my coding. Fucking pissed me off big time, gave me an excuse to try a different tune tho *silverlining*.
2014 ///M5 CP Tanzanite Blue/Cohiba - 11.15 @ 128.8 & 1.84 60' (2150' DA) - BPM Tune - MSR Intake - SSP DCT - SS DPs & HFC Mid Pipes/X-Over - E Race Muffs - 19" MT DRs... On to a new home.
      09-26-2016, 06:48 PM   #12
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
Originally Posted by Northern X5M View Post
Kris, is there any reason the dealer would have to reset or reflash the ECM or any modules during this procedure? When the dealership installed your kit they flashed over my tune and reset all my coding. Fucking pissed me off big time.
They should have only done the clutch relearn procedure. Nothing else. Someone at the dealership didn't know what they were doing...
This procedure has nothing to do with your tuning.
They might have tried to do a reset if there were fault codes during the procedure.
SSP
      09-29-2016, 04:48 PM   #13
schnell1982
Drives: FAST
If you find a shop with an Autologic...it can re-learn as well.
But the ISTA is the best diagnostic tool
      09-15-2017, 01:29 PM   #14
SQUEAK85
SQUEAK85's Avatar
Drives: 2013 BMW X6 5.0 4.4L / 2009 M3
Thanks, this helped me so much!
      10-28-2019, 11:18 AM   #15
dry87
dry87's Avatar
Indonesia
41
Drives: E92 M3
2008 BMW M3  [0.00]
2015 porsche macan  [0.00]
2015 bmw 435i  [0.00]
Hi Kris , i did instal the clutch as your instructions (in order that I receive from you)
I have problems when learning procedure
I did step 1.
In the 2 step :Touching point learning procedure
I try more than 4 times and it failed said “the value outside tolerance “
I haven’t try step 3,4,5 since step 2 ( touch point learning procedure) failed
Should i do in order or if 1 step failed I proceed with other steps ?
-Car in Neutral
-Car in Neutral
-Car in Neutral
-Car in Neutral
      10-28-2019, 08:56 PM   #16
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
I would check to make sure that the large snap rings for the clutch were installed in the correct places. Thick snap ring to hold the basket together. Thinner to hold the large clutch in place.
      10-31-2019, 01:48 PM   #17
MIM5
MIM5's Avatar
220
Drives: E92 335i
  [0.00]
Hi kris, I’m about to tackle this clutch upgrade this winter in my garage and remember that you mentioned a pdf for the clutch install on this forum once or twice. Is there a way I can get that pdf emailed to me?
      11-07-2019, 10:37 AM   #18
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
Email me at kris@sspperformance.com
SSP
      12-29-2019, 03:11 PM   #19
Madvillain
161
Drives: lada
great info but does anyone have instructions on how to install new clutch pack?i just order ssp spec R and while i wait i have removed everything but the clutch pack itself. next step would be remove that and to take the basket apart to remove old and install new....not trying to mess anything up so if anyone thats done it has instructions please post here or send me a pm
      12-30-2019, 08:46 AM   #20
MIM5
MIM5's Avatar
220
Drives: E92 335i
  [0.00]
Ssp sends you instructions with your clutch in the box. I’m about to do mine as well and got my clutches a few weeks ago 😀
      12-30-2019, 07:44 PM   #21
SSPKris
SSPKris's Avatar
Drives: Nissan GTR
Yes, the clutch will come with complete instructions on installation and proper procedures on how to do the adaptations.
You are always welcome to email or call if you need further assistance.
Kris
      01-07-2020, 02:36 PM   #22
Viper966
Drives: 2002 BMW m3
Kris
is the clutch install DIYable for somebody who is capable, but has never dissasembled a trans internals before
( i have changed the clutch on my E46 M3, and E60 m5 though)
m5post
