10-09-2016, 05:53 PM | #1 |
Rep 147
BE bearing review?
Sorry if the subject is misleading. Wasn't sure what to put.
I see several people doing preventive rod bearing maintenance and posting pics of OEM bearings after replacing them after xx,xxx miles. They typically show excessive wearing even after multiple OEM bearing replacements. I see the majority of people doing this approx. 30-50k (I know some people replace outside this threshold) and the next sets typically look the same as the original ones. So I'm looking for people that have installed the BE bearings and later taken them out to inspect and post there findings after a good amount of miles. I want to know if these bearing show the same wear characteristics of oil starvation. They claim to fix this issue and I'm looking for evidence to back it up. (If it exists. I searched around and didn't find what I was looking for so if you know where to find it, please direct me towards it. |
10-09-2016, 06:49 PM | #2 |
Rep 764
Drives: M3 E90 Jetblack
subscribed
check out my YouTube feature film:
10-09-2016, 07:27 PM | #3 |
5234
Rep 10,616
Come back in a few years when people are replacing bearings a second time as preventative maintenance. Only a few track cars or broken motor cara have been taken part again at this point. MFL seems to have taken apart the most, uses VAC bearings and reports good results.
I am at 20k on wpc treated stock bearings. Ill probably replace again in another 20k to be safe. Its too big of a job to do just for curiosity or to inspect but not replace. |
10-09-2016, 07:28 PM | #4 |
Rep 2,664
Drives: Goggomobil
+1 ... early days!
F86 X6///
///M Power-Belgium63382.00 BanjoPaterson160.50 |
10-09-2016, 10:11 PM | #5 |
Retired Curmudgeon
2985
Rep 4,047
Doc Oc had VAC bearings in his motor when it grenaded. The VAC bearings had 19k miles on them and were flawless. Similar clearances between the BE Bearings and VAC bearings iirc.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
10-10-2016, 09:35 AM | #6 | |
BimmerPost Supporting Vendor
1439
Rep 1,614
Regardless, VAC bearings are a small bit more clearance than stock. They are closer to stock than closer to BE Bearings. So I'd say no, they're not similar clearance to BE but similar to stock. Measurements of both appear at the BE Bearings wiki page. |
10-10-2016, 10:09 AM | #7 | |
Rep 1,017
Drives: 2010 E92 M3 6MT
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc |
10-10-2016, 10:21 AM | #9 |
1439
Rep 1,614
I am aware of this. I am speaking of the new VAC Clevite ones, not the old ones which were coated OEM bearings that reduced clearance.. Everything I said was documented at real time as the discoveries were made in the s65 bearing wiki. The measurements also don't support this notion that VAC is more in line with BE than OEM. Out of curiosity, has VAC ever published any of their own data? I haven't seen any if they have.
10-10-2016, 12:04 PM | #10 |
3751
Rep 2,907
Drives: 2011 E93 M3
I have installed BE bearings in 6 S65 client engines. None have reported back with any issues. BE are the only ones which are measured proven to increase clearance. To be fair, before BE came around I used WPC/OEM bearings and I haven't heard back on any of those engines either. Who knows how many miles any of those engines have by now.
Once the aftermarket started making copper/lead bearings I dropped OEM/WPC bearings. When the BE supply dried up for a while I installed the Clevite VAC bearings in my wife's M3 which sees daily driver duties and so far so good. Not many miles on them though so I'll monitor with Blackstone and report if anything happens. |
10-10-2016, 12:07 PM | #11 |
Rep 518
BE Bearings were just installed in mine at 124k miles. Sub'ing.
2003 M3 | SMG | KW V1 | Apex ARC-8s | 3.85 LSD | Cobra Nogaro | S2R Tuning Sunroof Delete | Billy Boat Section 3
10-10-2016, 01:55 PM | #12 | |
Captain Fatbelly
1423
Rep 1,994
///M Power-Belgium63382.00 |
10-10-2016, 02:11 PM | #13 |
Captain Fatbelly
1423
Rep 1,994
If it helps, this is what the Vac's looked like after 13.5k miles. BE has a similar coating and even more clearance so I'm sure you can expect similar results.
10-10-2016, 04:24 PM | #14 |
Rep 1,048
This is the thing we all really need to understand. When we have many consistent reports of what the bearings look like after extended use, its easier to make an informed decision.
Currently you have no freaking clue as to what the bearings are going to look like after 100K on them other than what the seller claims. That's not good enough IMHO. |
10-10-2016, 10:09 PM | #15 | |
4-6-8
234
Rep 990
As far as I remember BE bearings were made available to the public late 2015.
M3 E46 PY/Black
S2000 AP2 GPW/Tan |
10-11-2016, 08:20 AM | #16 | |
1439
Rep 1,614
Factory OEM bearings: Nominal: 0.00170 inch, range: 0.00135 - 0.00200 inch http://wiki.rcollins.org/core/index....5_Rod_Bearings VAC: Nominal: 0.00200 inch, range: 0.00160 - 0.00200 inch http://wiki.rcollins.org/core/index....ecifications_4 BE Bearings: Nominal: 0.00240 inch, range: 0.00180 - 0.00280 inch http://wiki.rcollins.org/core/index....ecifications_3 Not sure why this doesn't match what you just said if it really came from BE. |
10-11-2016, 08:30 AM | #17 | |
Rep 3,988
....or wait until you spun a bearing waiting for this 'proof' you seek.
Doc Oc1423.00 |
10-11-2016, 08:59 AM | #18 | |
Captain Fatbelly
1423
Rep 1,994
Now with the addition of these new measurements being rolled up, and the fact that all eight of them were indistinguishable the new baseline for 702/703 bearings goes back down to 0.00150 inch clearance, making it virtually indistinguishable from BMW's original 088/089 bearing clearances we've measured. Vac measured clearances from be: 0.00210 0.00190 0.00190 0.00210 0.00210 0.00190 0.00210 0.00210 This is all under the vac-clevite section. |
10-11-2016, 09:07 AM | #19 | |
Captain Fatbelly
1423
Rep 1,994
10-11-2016, 09:33 AM | #20 | |
1439
Rep 1,614
I can't find that text under either the 702/703 section or VAC-Clevite section. I have a feeling you're referring to the bearing wiki on this site that is no longer maintained. That is not the BE Bearing wiki. Another point about clearance ranges. Clearance measurements do not translate to clearance ranges as I think you have done. To develop a clearance range you calculate clearance from the smallest measured bore with the largest allowable journal size. That gives you the small range. You also calculate clearance from the largest measured bore with the smallest allowable journal size. This gives you the large range. I haven't checked your numbers,but I think you're just using those measured and looking at that range. That's not how it's done. |
atranho67.00 |
10-11-2016, 10:10 AM | #21 | |
Rep 979
Doc, Were these the older VAC or newer higher clearance VACS?
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... |
