10-20-2016, 03:05 PM | #1 |
Rep 855
Software options to disable cold air start and secondary air pump
Hi Everyone,
I have a CEL related to the secondary air pump failure (27AF -P1411). Failure is probably due to bad valves allowing the pump to be subjected to hot exhaust gases and burning out. I have the part numbers for the pump, valves and tubes however the labor involved looks complicated and expensive (since access to the valves/pump is difficult). (parts alone are $600-$700) As an alternative I was thinking of leaving the bad hardware alone and simply disabling the cold start/air pump altogether. I know there are tuners out there (turnermotosports/BPM) that have software to do this but they want $1k since their tuning involves increases in performance, rev limiter adjustment and other options. Are there other software tuning companies/options out there that can just allow me to disable the cold start/air pump at a lower cost? If anyone knows let me know. Thanks, Steve |
10-20-2016, 03:56 PM | #2 | |
BimmerPost Supporting Vendor
3387
Rep 7,541
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
10-20-2016, 04:53 PM | #3 | |
Rep 855
Also I've read that disabling the cold start may cause premature failure of the cats over time due to the rich unburnt mixture not being warmed up or pre-burned by having the air pump intervene. Is this true? |
10-20-2016, 07:01 PM | #4 |
///M Powered for Life
11490
Rep 10,329
Mike Benvo is a tuner
MilehighM3915.00 |
10-20-2016, 07:19 PM | #5 |
3751
Rep 2,907
Drives: 2011 E93 M3
It will shorten cat lifespan yes. You can get a used air pump for $100 and valves for $40 per side. The labor isn't that bad... And it's diy easy.
I would suggest replacing damaged parts rather than mask their leaks with an electrical modification. |
M43S7RO503.00 |
10-21-2016, 02:24 AM | #6 |
Rep 855
The pump is easy removal, but does anyone have a DIY on how to remove the valves?
It looks pretty difficult to access the valves from the top or bottom of the car. Any help would be appreciated. |
10-21-2016, 09:09 AM | #7 |
3751
Rep 2,907
Drives: 2011 E93 M3
I have not seen a diy, but it's a simple matter of gaining access to them, which means just taking off the strut brace bars, intake plenum, cabin filter cowls, and using a small 10mm combination wrench and socket to unscrew the two nuts on each valve.
10-21-2016, 12:21 PM | #8 | |
3387
Rep 7,541
Yes, it's richer on cold start, but this is irrespective of whether the cold start heating cycle is on or not. We offer this. You can PM/Email/Call as I'm not allowed to discuss pricing here. Thanks
10-21-2016, 12:28 PM | #9 |
Rep 5,483
Rich mixture + cold cats for longer = fouled faster, the catalyst doesn't self-clean properly when it's cold and the longer it's cold the more likely you're going to foul it; whether it matters is up for debate, probably doesn't matter if the car gets warmed up whenever it's driven so it can't go into a death spiral.
