12-28-2016, 10:24 AM | #1 |
25
Rep 49
New brake pads installed.
Hello,
I have just changed my front pads because they were completely worn, but I didn't have any warning - just visual inspection. One day after the change I got a warning - that pads are worn and need maintenance. I have reused the old brake-pad sensor as it was undamaged. The dealer says that I need a new sensor anyway to be programmed as the car realized that the pads are new. Is that true? Thanks! |
12-28-2016, 12:52 PM | #2 |
21121
Rep 20,741
Drives: 2021 911 turbo
Not true. The dealer is trying to rip you off.
There are two different type of warning for brake pad wear:
Note, that if your sensors were not worn, there was still life left in your pads (i.e. not "completely" worn). Further, ensure that you did not damage or miss-install the sensors when replacing your pads, because it the sensors are indeed damaged, they will need to be replaced.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 12-28-2016 at 04:56 PM.. |
01-07-2017, 04:12 PM | #4 | |
Rep 966
You have to reset the brake pad wear percentage in the service settings to allow the percentage to go back to 100% Need a diagnostic computer for that |
01-07-2017, 04:21 PM | #5 | |
21121
Rep 20,741
Just need to access the service menu (see link in my previous post)
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
