01-03-2017, 03:37 PM | #1 |
Rep 912
Z4 Aftermarket Steering Wheel (aka PITA)
Hi All,
Thought I'd start a thread to vent, because there isn't much info out there. I'm installing an aftermaket steering wheel and have hit a wall because I do not want my SRS Airbag light on. I've found a couple of threads (AFTER MUCH GOOGLING). This is the thread you want: http://www.m3forum.net/m3forum/showthread.php?t=484342 ANYWAY. I've installed the resistors that came with the wheel, but I think I did it in the wrong order with the battery as now I've got the airbag light that won't go off. So now I've bought this: "BMW-USB-OBD-Diagnostic-cable" http://www.ebay.ca/itm/BMW-USB-OBD-D..._qi=RTM2247625 So that I can reset my stuff. I'm not that peeved because this software will be usefull or at least fun to play with in other ways. I'll keep you up to date on the result of the install and some information about what to do or not do at some point. I'm just frustrated because what was generally easy for install, is just taking that extra bit longer. cheers. |
01-04-2017, 11:01 AM | #2 |
2289
Rep 12,565
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Steering wheel, seats, etc... anything interior race related is a PITA in this car. Curious to see how it turns out. I really wanted an aftermarket wheel but modifying the hub seemed like a pain so I just ended up reupholstering the factory M wheel in alcantera.
01-17-2017, 03:18 PM | #3 |
Rep 5,329
aftermarket wheel in this car is serious PITA.... I'm pretty sure you will have to relocated the airbag and wiriring to a different location to get the airbag light off..... which imo is totally nuts thing to do, but thats what people are doing to get this to work.....
the stock wheel is luckily one of the nicest OEM wheels I've come across, with some simple re working it really is a beautiful thing to behold!
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
Residentj3553121.50 |
01-17-2017, 03:51 PM | #4 | |
Rep 912
Between software and resistors there's a way. |
02-04-2020, 04:37 PM | #5 |
I like Coffee & Z4s.
106
Rep 366
Drives: 2007 Z4MC
reviving, any way to make this work with just software or resistors?
02-05-2020, 10:39 AM | #6 | |
Rep 912
I had this working with software and resistors. But made another modification (can't remember what but unrelated to the wheel) and didn't disconnect the battery. Upon startup the light came back. I haven't made an effort to try all over again. It's a good reminder to not drive like an idiot. The first post of this thread is the solution I followed. Resistors are 2.3 - 2.5 ohm. Last edited by 3GFX; 03-06-2020 at 03:06 PM.. |
