BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
Mporium BMW
      04-27-2008, 10:46 PM   #1
rawedge2
rawedge2's Avatar
63
Drives: 05 STI - 08 M3
Anyone do CDV (Clutch Delay Valve) Mod??
If you are new to what this is heres the scoup:
http://www.zeckhausen.com/CDV.htm
--here's the thread the topic died in - http://www.m3post.com/forums/showthr...&highlight=cdv
so simply there is a cdv in the e92 m3
i have heard it makes an improvement in the 335 feel mostly between 1st and 2nd..
anyone do this mod yet on an m3?
RissRacing.com makes a fit all bmw 6MT model for $29
-that would fit?
or is this mod not worth it..? i dont see how it could harm the car at all if you drive correctly..
      04-27-2008, 11:16 PM   #2
sayemthree
sayemthree's Avatar
597
Drives: ‘20 X3mC ‘20 Raptor ‘04 X3 6mt
dont knwo but it seemed a big deal inthe e46 M3 - I never did it - the car shifted fine for me.
Fore Sale Rare 6 speed manual X3 3.oi silver over grey. PM me
      04-28-2008, 05:54 AM   #3
SS32
SS32's Avatar
156
Drives: 2008 M3
I plan on doing it at some point. I never took the CDV out of my E46, but I'd love to feel the car without it, or with a modified one.
      04-28-2008, 11:14 AM   #4
sejoon85
sejoon85's Avatar
20
Drives: AW e92 m3
Ive tried to contact Riss racing regarding if it will work on the e92 m3. Never got a reply
      05-01-2008, 12:22 AM   #5
BPMSport
BimmerPost Supporting Vendor
BPMSport's Avatar
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Yes, I removed it yesterday. I like it much better without it.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
      05-16-2008, 05:35 PM   #6
rawedge2
rawedge2's Avatar
63
did you simply remove, or did you order a replacement part.. if so which one...???
      05-16-2008, 06:03 PM   #7
SnowsM3
SnowsM3's Avatar
11
Drives: 2011 X5M
What exactly does it feel like without the CDV? Does it make the pedal travel resistance more linear? I'm having trouble getting used to my clutch right now as is and might be interested if someone can explain what it feels like to them before & after. Thanks!
Time you enjoy wasting is not wasted time.
      05-17-2008, 01:47 AM   #8
hamann330ci
hamann330ci's Avatar
Drives: 2002 E46 330ci
      05-17-2008, 07:00 PM   #9
Steveo58
-Steveo-
Steveo58's Avatar
Drives: 2008 M3
All the CDV valve dose is reduce the internal size of the clutch line, thus limiting the amount of fluid that is able to pass though, as deturmined to be the best rate by BMW. It actually makes the clutch slip slightly, and causes additional wear, and keeps anyone from shifting faster then they deturmined.
All you have to do is remove the valve and bolt the line back together, then re-bleed the system. You can also pull the CDV out and simply drill the hole out to the size of the clutch line and then put it back in. The one Riss and others sell are just stock units that have been drilled out - anyone can do it. This also keeps things looking stock so if anything clutch-wise goes wrong BMW can't see it was modified.
It defintely makes a difference, I did it on my old E46 M3 and will be doing it on my new E92 shortly!
Hope this helps...
-Steveo-
      05-20-2008, 05:30 PM   #10
BPMSport
BPMSport's Avatar
2000 BMW M5  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Originally Posted by hamann330ci View Post
Simply remove it. Nothing else. You can bolt the line up directly without the CDV.
      05-20-2008, 10:59 PM   #11
Steveo58
-Steveo-
Steveo58's Avatar
Drives: 2008 M3
Just did the mod today. drilled out the stock unit to the size of th clutch line... MUCH better! Perfect shifts through the gears...
-Steveo-
      05-20-2008, 11:20 PM   #12
edlms
edlms's Avatar
10
Drives: E92 M3
hi... can you elaborate?
is there a difference in feel?
does the bite point differ? does the bite point require less pedal travel eg if you need to half clutch?
what do you mean by perfect shifts? does it affect the gear shifting?
thanks for your time in answering my questions.
cheers
      05-22-2008, 12:28 PM   #13
Steveo58
-Steveo-
Steveo58's Avatar
Drives: 2008 M3
cheers
Sure... It doesn't change the bite point or the actual feel at the shift knob, but it improves feel from your left foot on the clutch pedal. With the CDV in I thought it felt on the numb side at the pedal, but with it out you have more of a direct connection.
It also makes the shift from first to second much smoother and easier. It's really quite an easy mod to do, and there is no need to buy the aftermarket parts, just drill the existing one out or simply remove it. Hope this helps...
-Steveo-
      05-22-2008, 04:01 PM   #14
ChinoOrtega
ChinoOrtega's Avatar
Guatemala
50
Drives: 991 C2S
Here's the DIY
http://www.e90post.com/forums/showthread.php?t=29828
      05-23-2008, 01:07 AM   #15
edlms
edlms's Avatar
10
Drives: E92 M3
thanks...
cheers
      06-07-2008, 03:12 PM   #16
xxo0oxx
Drives: m3 e92
anyone have the intsruction in pics of this process odne on a E92 M3 i wanna do it but still not sure how
      06-07-2008, 09:18 PM   #17
GregW / Oregon
Commander-In-Chief
2122
Drives: 2023 M2 Coupe, 2020 GLE 450
Only issue with that is the dealer could deny clutch or transmission warranty or maintenance coverage if you later have an issue. That's why Zekhausen sells the stealth modified ones.
Frankly, I felt no difference when I had my E46 M3 one removed after warranty.
Greg Lake Oswego, Oregon, USA
2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450
      06-11-2008, 04:27 PM   #18
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
2006 Infiniti - G35 ...  [8.00]
hahaha good luck with RR. u have to pay them and beg them to get them to talk to you.
Hope this helps...
awesome post. thanks!
again awesome. can u help me do mine?
on 335 it makes a huge difference. it's worth a shot if it's improves the 1-2 shifts. this + RE ssk that's coming out should make me hella happy
      06-11-2008, 07:34 PM   #19
GregW / Oregon
Commander-In-Chief
2122
CDV modification
Zeckhausen claims drilling can lead to leaks: http://www.zeckhausen.com/cdv.htm
      06-18-2008, 02:54 AM   #20
Riss Racing
Drives: E60 M5/E92 335/HUMMER H2
Some things never change Manits
If you need help feel free to PM me I'm on at 1am to answer questions....any other vendors doing this? Thanks!
      06-18-2008, 11:32 AM   #21
!Xoible
Drives: ....
2008 M3  [4.00]
2007 335i  [9.00]
2008 528i  [8.00]
^^^ charlie style communication aye?
      02-02-2014, 09:24 PM   #22
Time Lord
Time Lord's Avatar
Drives: 2018 F80 ZCP
is there a DIY on this from start to finish?
2018 F80 ZCP
m3post
