06-16-2017, 03:16 AM | #1 |
Rep 163
Wheel alignment queston? Thoughts
Hi guys, i went and got a wheel alignment today and have taken a picture of the sheet they gave me with all the numbers/ stats. I feel like it may be out still.
How do these numbers look, are they close enough to the proper specs? Thanks in advance |
06-16-2017, 06:35 PM | #3 |
Rep 163
06-17-2017, 07:23 AM | #4 |
Rep 3,993
Imo that is a shit alignment job.
You want left and right toe to be as close to eachother as possible. Rear camber should be even. I prefer less toe than factory specs. |
06-17-2017, 07:31 AM | #5 |
Rep 163
I think I ll have to go get it redone somewhere else, where they actually know what they are doing. This is the second time I ve had issues with alignment at the particular shop. The first time I went there they gave me an alignment for an i8!! Lool won't be going there again
xQx902.50 |
06-17-2017, 07:45 AM | #6 |
Rep 410
I have attached the TIS alignment specifications for E92 M3.
Total toe = Individual toe x 2. Something I noticed on the template is the +/- 1.7mm exceeds what should be the target data of +/- 0.8mm From the results the rear was brilliant before the alignment and after the alignment the Toe and Camber are outside the target. The front Toe was worse before the alignment and is now within target. I used 640mm as tyre diameter (225/35 19") to calcualte Total toe of 10' to get Total Toe 1.86mm Most of the alignment machines use a fixed diameter that is why there can be some small errors in measurement for target values. Take along the BMW AG specifications for comparison. |
06-18-2017, 11:17 PM | #7 | |
Rep 163
I ll keep you up to date Wish me luck |
06-19-2017, 01:26 AM | #8 | |
Rep 410
http://www.e90post.com/forums/showpo...&postcount=521 |
bosse92m339.50 |
