10-02-2017, 08:19 AM | #1 |
Rep 247
F83 Coilover Options
Does anyone know if I can run any coilover options available (KW v3, JRZ RS 2 touring, 3D Design, etc) or does it have to be f83 specific?
I know the HAS kits are f83 specific but are the coilovers too? Thanks in advance! |
10-02-2017, 07:20 PM | #2 |
Rep 5,548
I believe the only difference is spring rate - higher rates on F83 because of weight.
KW V3s come with a specific spring rate so you may need a kit that's designed specifically for the F83. However, any suspension setup that allows you to select custom spring rates will work fine on a F83. What are looking for from a new suspension setup? There are a lot of nice suspension options available for the F8x. |
10-14-2017, 01:54 PM | #3 | |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
Let us know if you have further questions. |
10-15-2017, 02:33 PM | #4 |
Rep 247
10-15-2017, 06:13 PM | #5 | |
3847
Rep 54,376
Drives: F80 M3
If you would like lower spring rates, we could provide something just a bit lower but not at the same rates some street F80/82 owners are running. Those low rates will cause the F83 platform to bottom out too often. |
