10-05-2017, 03:48 AM | #1 |
The G8X is a disaster. 🤮
931
Rep 988
Which camber plates definitely work with Ohlins R&T?
I'm having difficulty determining which camber plates will definitely work with the F80 Ohlins R&T suspension. One user has said the TC Kline camber plates will work, but TC Kline themselves disagreed.
Please chime in if you've got R&T suspension with camber plates. I'm curious what you had to do to make them work and not rattle/clunk. |
10-05-2017, 05:40 PM | #2 |
Rep 52
We do offer our adjustable camber/caster plates that are built specifically for the Ohlins R&T system. The R&T coilovers for the F8X M have different specs(spring inner diameter, strut shaft diameter, etc) than most aftermarket systems for this chassis, however we do have all of the correct information needed to build these. I'd say approximately 25% of our orders for the F8X M plates are for the R&T.
I've yet to ride/drive one of these cars with the R&T system; seems like a pretty popular choice for the F8X? Trevor |
10-06-2017, 04:29 AM | #4 |
Rep 283
I had my adjustable camber plates custom made for the R&T, roundabout 350 EUR. It's another huge difference with a bit more negative camber. Nonetheless i'm selling my system in the next few weeks and will go with KW CS 3-way instead.
@GC: You'll love the riding especially when using proper (=softer) rear springs than the ultrastiff Öhlins original springs (230N/mm)...
Kraut-Hero & (occasional) San Franpsycho
10-06-2017, 08:42 AM | #5 |
931
Rep 988
I did opt for softer springs. Mine will be 286 lb/in front and 687 lb/in rear. I want to maintain the stock ride height, but go a little stiffer, and get a lot more damping.
10-14-2017, 01:52 PM | #7 |
Supreme Allied Commander
3847
Rep 54,376
Drives: F80 M3
TC Kline Racing just confirm that he has the special spool/spacer to make his plates work on the Ohlins R&T.
richf8079.00 |
12-25-2022, 02:36 AM | #9 | |
Rep 3
I am having a 3 bolt adaptive stock suspension currently. |
