05-21-2008, 05:18 AM | #1 |
Rep 56
Please Help!!!Interior LED light replacements
I want to do LED light replacement. I am looking for Super White LED bulbs at http://autolumination.com. I have couple question regards to different type of LED bulbs because most of the diameter are different and the overall size and I couldnt find side facing led for the trunk. which would be the perfect solution for our car? and Which one is gonna fit on doom light, and 2 map light, 2 footwell, 1 for trunk and 2 for licienseplate.
$8.99 each!! "Introducing the New SMT Tower 194 168 W5W 2825 Outfitted with the latest Super High-Flux SMT Leds The Widest, Brightest and Best 194 168 W5W 2825 Ever Made! Only 10mm diameter x 27mm overall"??????? $10.99 each! "Outfitted with the latest Super High-Flux SMT Leds The Widest, Brightest and Best 194 168 W5W 2825 Ever Made! Only 11mm diameter x 38mm overall"?????? $7.99 each! "Introducing the New & Improved Outfitted with the latest Super High-Flux low profile Leds Designed especially for gauges, and applications requiring a large uniform field of bright light Note: These have the all metal heat sinks for constant-on applications to reduce heat related failures Only 9mm diameter x 24mm overall""???? $7.99 each!! "Introducing the Super Nova The Widest, Brightest and Best 194 168 W5W 2825 Ever Made! Outfitted with the latest Super High-Flux low profile Leds. Aluminum heat sink keeps them cool in hot & smaller housings to avoid heat related failure Designed especially for gauges, and applications requiring extra cooling 12mm diameter x 23mm overall"??? Thank in advance~ |
05-21-2008, 09:14 AM | #2 | |
More than you can afford pal....ferrari
181
Rep 1,471
05-28-2008, 06:28 PM | #3 |
Rep 25
Drives: 2003 Z4R 2.5i
I was unable to find an LED that would fit in the center w/o having to mod anything. I was able to make the 6LED bulb fit, had to make the center hole a little bigger with a file to make it fit. Had no problems/damage with that, end results = bigger hole, brighter interior. Also replaced all my amber interior leds to white too, now that was a challenge. posted pix in album.
05-28-2008, 09:03 PM | #4 |
Rep 267
I just saw the pictures in your album.. WOW how did you change the amber leds to white??
2007 Z4 3.0si Step/Premium/Xenon/HeatedSeats/AutoTop/M6Wheels 2007 328xi Step/Premium/Sport/Xenon |
05-29-2008, 04:56 AM | #5 |
Rep 25
1st had to take out the switch, panel etc. to see which kind of LED it was. Hard part was trying not to break a tab(s) off the plastic housing or worst the circuit board itself, then find out how many LEDs i needed, total came out to 150+ leds, soldering iron and steady hands..... very very steady hands.
05-29-2008, 07:10 AM | #6 |
Rep 267
Wow.. props.. how long did it take you to do everything from start to finish?
05-29-2008, 02:21 PM | #7 |
Rep 25
Thanks! Started taking everything out on a friday night, r&r leds finished up sun evening, took breaks of course, If i did it straight i would have to say 5-8 hrs +/- 1 or 2.
