11-27-2017, 11:31 PM | #1 |
BimmerPost Supporting Vendor
1331
Rep 872
Anyone have a front mono ball kit installed?
I'm looking at getting either the Fall Line or Dinan mono ball kit for my F82. Was wondering if anyone local has a set installed on their F8X and willing to give me a ride so I can get a sense of what the NVH is like before I bite the bullet...I'm located in Tysons Corner, VA.
Speed & Tech Motoring
23585 Overland Drive, Unit 178 Sterling, VA 20166 (Headquarters) 23541 Pebble Run Place, Unit 140 Sterling, VA 20166 (Satellite shop) |
12-10-2017, 11:06 AM | #2 |
1331
Rep 872
Welp....looks like I'll be the guinea pig then.
cotmfk2058.50 |
12-11-2017, 07:22 AM | #3 |
Rep 6,119
Cool, let us know the results!
When you say impact instead of affect/effect, you are communicating that you don't understand the difference between the two words, and are too lazy to learn.
12-28-2017, 08:17 PM | #4 |
Rep 5,701
I have the BimmerWorld FCAB installed on my M4 and there's no measurable change in NVH. I also have GC camber plates and MCS 2WR dampers installed - camber plates did increase NVH slightly.
06-19-2018, 09:30 PM | #5 |
#LSBM3
1423
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
Did you ever end up installing the Dinan mono ball kit? Just picked up the kit for my F80 and will have it installed in the next couple weeks. Any tips for the install?
/// M3 |
06-20-2018, 12:07 AM | #6 |
1331
Rep 872
I have the fall line ones but the installation should be pretty identical. When you remove the thrust arm, it's easier to remove the wheel liner to get access to the bolt rather than going from under the car. It's a super long bolt too so you'll need to unbolt the radiator (just one screw if i remember correctly) and move it out of the way to fish out the bolt. Other than that it's pretty straight forward popping out the bushing and pressing in the bearing. Let me know if you have any other questions.
Brasko1422.50 |
06-20-2018, 08:51 AM | #7 | |
#LSBM3
1423
Rep 1,973
Drives: 2016 BMW M3
Appreciate the info. Didn't realize the radiator may need to be moved out of the way. I'm guessing no alignment was needed after the install?
/// M3 |
06-20-2018, 11:24 AM | #8 | ||
1331
Rep 872
Brasko1422.50 |
