12-24-2017, 11:33 AM | #1 |
Rep 488
BMW MPerformance HAS - Which camberplates?
On my new 2018 Competition, after reading some reviews, I've decided to give the M Performance HAS a try. However, I really want the added camber adjustments via camberplates.
I'm totally torn between the TC Kline and Ground Control plates. Has anyone paired these with the M Performance with either of these camber plates? And how is the noise and vibrations associated with these and is the mating of the two suspension components relatively seamless? Thank you in advance.
IG: @circuithunter
12-25-2017, 04:43 AM | #2 |
21117
Rep 20,741
Drives: 2021 911 turbo
I almost went for the TC Kline camber plates because they were the first to market. I decided to cancel my order when I found out they are only adjustable in step increments, preventing a precise adjustment of front camber.
I ended up installing GC camber plates. They had served me well on my E46 and E92 and they are very well made. They allow for precise adjustment of camber to get it perfectly to your specifications and ensure equal left and right camber levels. Since the MP HAS use the standard top bearings, I don't see any issues of pairing them with GC camber plates. IIRC, there are few members that have already successfully paired MP-HAS and GC camber plates.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
12-25-2017, 10:15 AM | #3 |
Rep 488
Thanks for the reply. I did see that TCKR only offers set camber adjustments. I guess the positive is once they are set the aren’t moving but they do lack fine tuning. Lack of noise and long term rigidity is my primary focus. Have you liked the GC pieces with your application?
12-29-2017, 11:16 PM | #4 |
Rep 80
Circuit Hunter Have you considered the Ground Control HAS?
https://groundcontrolstore.com/colle...conversion-kit |
spr92.50 |
12-30-2017, 01:37 PM | #5 |
Rep 488
^I did give it a thought but ended up getting the MPerformance HAS. I decided to pair with GC plates. I’ll report back once I get this setup installed and have som miles put on.
IG: @circuithunter
12-30-2017, 03:37 PM | #6 |
Rep 715
I plan on doing the same. Have the GC plates already, still vacillating on the MP HAS. Post your impressions when you have them.
M4 Times (PSC2): Sandown: 1.21.76 Winton: 1M Times (PSC2): Phillip Island: 1.53.09 Sandown: 1.24.03 Calder Park: 1.07.31 Winton: 1.36.71 |
12-30-2017, 10:33 PM | #7 |
Rep 488
Will do!
IG: @circuithunter
01-26-2018, 04:27 PM | #8 |
Rep 1,089
Outcomes? Anyone running GC full setup? Their collar adjuster seems sleezy that if you don't option it it does not have a lock???
F80 M3 HRE FF04 275/305.
01-26-2018, 06:00 PM | #9 |
BimmerPost Supporting Vendor
8215
Rep 18,823
Drives: BMW
We prefer the Ground Control plates.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
GCSystems56.00 |
02-08-2018, 10:58 PM | #10 |
Rep 488
Ground Control plates paired with MP HAS has been great so far on my 18" ZCP F80. The plates do increase tire noise by about 15% and stack height doesn't appear to be an issue. Being able to adjust camber is a great benefit to the already very enjoyable competition package. The total ride firmness in my opinion increased by about 10% (on lowest ride height setting). If you are one that finds the comp. pack ride to already too stiff, this combo is probably not for you. I find it pleasant for daily driving with great performance.
IG: @circuithunter
MPoweRo428.00 |
