01-14-2018, 07:31 PM | #1 |
Rep 2,799
CP Ride Height?
It had appeared to me that the CP car looks taller than non-CP car. So, today, I measured the brand new CP car and it sits around 0.3 inches taller than the non-CP car, comparing stock to stock. On the contrary, I expected the reverse, that CP cars would be lower than non-CP due to upgraded springs.
Did you guys notice this coming from non-CP cars? I understand the springs and shocks are brand new and may settle a bit, but my car was in the dealership lot for a month. Should it not have settled by then? Thanks
2021 M2C HS/6MT/Exec/Moonroof
01-14-2018, 08:29 PM | #2 |
Rep 2,419
*calling the ZCP vs non ZCP squad*
2012 BMW M3 E93 (Fire Orange)
Akrapovic Evolution Titanium Exhaust Arkym Style Front Lip/CF Diffuser/CF Side Skirt Extensions LUX H8 189 Angel Eyes 2023 Nissan Z Performance (Ikazuchi Yellow) |
01-14-2018, 09:01 PM | #4 |
Rep 2,924
Bigger wheels, 20" on ZCP.
Currently: '24 Mercedes G63 | '24 Porsche GT3 RS | '24 Volkswagen GTI
Previous BMWs: 340i, 740i, 745Li, M3, M4 Previous Others: Audi, Ducati, Honda, Infiniti, Land Rover, Mercedes-Benz, MINI, Mitsubishi, Porsche, Toyota, Volkswagen |
01-14-2018, 09:31 PM | #6 |
Rep 2,799
Yes you are right and when i saw the wheel gap in front was surprised and took it back to dealer to see if they removed the shipping block and the tech confirmed that there is no shipping blocks and it will take time for suspension to settle but if the car was in the lot for a month I expected that to happen by now unless they did not do PDI recently
01-14-2018, 09:32 PM | #7 |
Rep 2,799
01-14-2018, 09:39 PM | #8 |
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Here are the tire sizes:
Non-ZCP (front) 255/35R19 26.028" dia. (rear) 275/35R19 26.579" dia. ZCP (front) 265/30 ZR 20 94Y 26.26" dia. (rear) 285/30 ZR 20 99Y 26.732" dia.
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
01-14-2018, 09:48 PM | #10 |
Rep 2,799
.3 inches from ground to fender and I am curious to know because CP having upgraded sports suspension should be lower than non ZCP cars. The front wheel gap is ugly and did not expect it, I am not whining but want to know
01-14-2018, 09:52 PM | #11 |
Rep 8,852
Maybe they didn't remove the transport blocks
01-14-2018, 10:14 PM | #12 |
Rep 2,799
01-14-2018, 10:17 PM | #14 |
Rep 8,852
There are several cases of people driving them with the shipping blocks on after delivery. They can be driven that way because they drive them on and off the ship and transport trucks with the blocks in.
boss2k1090.00 |
01-14-2018, 10:20 PM | #15 |
2228
Rep 1,897
Upgraded suspension doesn't equal lower ride height. The upgraded springs on the ZCP entail recalibrated spring rates. The ride height should be unchanged from non-ZCP. I expect it should settle with time. You really have two options if it bothers you that much: leave it as is or lower with aftermarket springs or coilovers. I haven't noticed a material difference but then again I did not measure.
boss2k1090.00 |
01-15-2018, 07:20 AM | #16 | |
21117
Rep 20,741
Drives: 2021 911 turbo
Ride height, by pure definition is the vehicle's ground clearance (the shortest distance between a flat, level surface, and the lowest part of a vehicle). Wheel gap is often confused to ride height because that is what folks look at from as esthetics point of view. In terms of handling performance, what matters is the height of the centre of gravity. These three parameters are not directly related, each parameter can be change without affecting the others. However a single change can affect all three. For instance, installing shorter springs on a car reduces ground clearance, reduces fender gap and lowers the centre of gravity. Lowering the centre of gravity improves handling because it will induce less side-to-side weight transfer during cornering, which increases the total grip generated by the tires.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 01-15-2018 at 07:31 AM.. |
01-15-2018, 08:04 AM | #17 | |
Rep 4,983
This. May just need time to settle too.
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
boss2k1090.00 |
01-15-2018, 08:05 AM | #18 |
21117
Rep 20,741
According to BMW literature, the CP should have the same ride height as the non-CP.
According to Eibach USA measurements (sample of one), the CP rides slightly lower than the non-CP.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
