01-16-2018, 08:00 AM | #1 |
Rep 154
Help me understand lowering/HAS
Greetings all,
Now that my f80 has hit 2k miles, I am interested in lowering the front end to get rid of the giant gap. The rear is fine, but would lower it also if needed. Details are as follows: '18 f80 competition package. 20in rims, running stock PSS. I want to keep all the factory suspension that the comp pkg offers, simply lower the car. I would like to keep the turning radius, and not have to freak out about speed bumps, and or other conditions that I may experience, as this is my daily driver. This is mainly for cosmetic reasons, I just cant stand how the front is so high. Should I go with HAS only or do I need anything else? Any advice as to the best approach to this would be greatly appreciated! |
01-17-2018, 06:46 PM | #3 |
Rep 2,799
It's not recommended to put aftermarket spring only on front, you need to do for all
Even I am thinking of eibach and called them and their spring rates are lower than stock CP,will that make ride softer because I want same stiffness as stock CP |
01-17-2018, 09:15 PM | #4 |
Rep 2,180
With the ZCP and Eibach in front-only the difference is 7% softer while being lower and at the same drop as the OEM springs in the rear. That is what the OP asked -daily driver/cosmetic reasons. I would not suggest this mod for at limit handling/track.
02-15-2018, 11:57 AM | #7 |
Rep 1,009
In order to reduce the wheel gap, you have to install a HAS kit or springs. A HAS kit would allow you to dial in the desired height front and rear while springs are preset heights. With a lowered car there are inherit risk. Most notably scraping your front lip or bottoming out. If you cannot manage those risks then keep your car at stock height.
karbonM330.00 |
02-22-2018, 02:27 AM | #8 |
1538
Rep 1,665
I had KW HAS. At first, it was great. Car handled and rode really well. After a few thousand miles, the stock shocks couldn’t handle the increased spring rate and lowered ride height and began to wear out. Car started to feel floaty on the freeway and would get upset more easily over sharper bumps. Overall performance degraded to the point where I eventually replaced my suspension w/ Bilstein PSS10 coilovers.
I have lowered every single car I’ve ever owned. Sometimes spring only kits work well for tens of thousands of miles. But most of the time, they don’t. The reality is, a full coil over set up or matched springs and shocks with firmer damping are always better than springs only paired with stock dampers that are not designed to withstand the increased spring rates and lowered/reduced suspension travel. |
02-22-2018, 06:22 PM | #9 | |
Rep 154
02-23-2018, 12:37 PM | #10 |
Rep 1,495
I had similar concerns, OP - that is, I wanted to retain the factory ZCP characteristics, just lessen the "gap" in the front of the car. I went with MPHAS. Sure, it's an expensive alternative to other options like KWHAS or springs (especially when installed via dealer), but the peace of mind that comes with the warranty backing was worth it to me.
When installed by-the-book, this kit doesn't allow for an aggressive drop, but it does allow you to close up the front gap quite nicely and retains (IMO) virtually identical ride characteristics to the ZCP springs. As far as handling goes, I haven't pushed the car with the MPHAS installed, but it certainly feels more planted in daily driving. It comes down to whether or not closing that gap and retaining warranty is worth $2k+ to you. Good luck!
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S |
02-23-2018, 12:42 PM | #11 | |
Rep 154
I'm currently having a similar thought. Have any pics of yours after the install? |
02-25-2018, 08:02 AM | #12 |
79
Rep 321
A friend of mine took delivery of his '18 M3 Comp Pack and immediately fitted a set of the Eibach Pro Kit springs. His car now feels softer and less controlled. I have recently taken delivery of an '18 Comp pack M4 and was also about to fit a set of the Eibachs as I had a set on my previous '17 non CP car where I felt they actually improved that car. Having now had a ride in his car I feel it would be a detrimental step on a '18 CP car and have decided to fit MP HAS instead as I believe (only from what I've read) that the MP HAS springs are the same rate as the CP cars..
karbonM330.00 |
02-27-2018, 08:40 AM | #13 | |
Rep 154
Good to know. I'm being told by multiple people that over time, HAS will destroy the stock shocks. Not sure after how long, but just something to keep in mind. |
02-27-2018, 09:06 AM | #14 | |
1538
Rep 1,665
If you just want to close the front gap, I’d suggest getting the MP version of the KW HAS kit, keep rears at stock height and drop the front just .5” or maybe .75” at the most. Minor lowering should prolong the life of the stock shocks. Ultimately though, they are still heavier springs and will wear out the shocks faster than stock springs. |
02-27-2018, 09:12 AM | #15 | |
Rep 154
IG: @karbonM3
03-09-2018, 11:28 AM | #16 |
Rep 608
03-09-2018, 12:52 PM | #17 |
Rep 16
I also have a 2018 M3 ZCP. I wanted to get rid of the front gap so I got Swift Springs installed. They actually just finished the install today, I will post pictures of it later and report the differences I feel.
2018 BMW M3 Alpine / Sakhir / DCT
Competition Package M Performance Package Swift Springs / 15mm H&R Spacers |
karbonM330.00 |
03-10-2018, 11:55 PM | #18 |
Rep 16
Here are some pics of my 2018 ZCP with swift springs. First impressions after driving it for 2 days, love it!! Feels like stock ride quality but cornering feels so much tighter. No regrets at all. Best of all, front wheel gap is gone. I have some spacers on there as well, no rubbing issues and stance is perfect in my opinion.
dpgfunk332.50 |
03-11-2018, 05:58 PM | #20 |
Rep 16
1 inch in the front and .4 in the rear. I think it's perfect with 15mm spacers
03-12-2018, 11:16 AM | #21 | |
Rep 154
Also, is it necessary for coding and alignment to be done afterwards?
IG: @karbonM3
03-12-2018, 11:54 AM | #22 | |
Rep 2,527
