02-06-2018, 12:37 PM | #2 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
a couple of friends that are local have had some rough idle issues, the tech that fixed both are stating icv. an error on the icv can actually throw codes related to actuators.
2009 M3 DCT ESS625+ SOLD 2015 M4 BSM/Silverstone F4LCON @texasMclub IG @jagemoets |
02-06-2018, 01:23 PM | #3 | |
Rep 500
If so, i had EAS run both Bank 1 and Bank 2, the result both are in good shape. only code they catch was 279E which is oil condition sensor.. but after they clear it, the code (279E) is gone. |
02-06-2018, 01:26 PM | #5 |
Rep 115
idle control valve. sounds like it.
02-06-2018, 01:38 PM | #6 |
Rep 500
thanks guys...
1) ICV (I will look into it) 2) New Century BMW told me to change out the ignition coil , they said, a lot of time, the computer wont able to catch the symptom on ignition coil. |
02-06-2018, 01:57 PM | #7 | |
Rep 3,737
Drives: 2018 M2
does it happen after you fill up? does it happen when you hit the brakes? ICVs often throw codes and people are usually quick to blame an ICV but theres a bunch of posts where it was not the ICV itv was actually the fuel vapor purge valve which will never throw a code, rough idle even stalls |
02-06-2018, 02:52 PM | #8 | |
PAZUZU
545
Rep 2,058
Drives: '15 M4
02-06-2018, 03:23 PM | #10 | |
Rep 500
1) Nope, it does not happen after I fill up 2) Nope, it does not happen when I press the brake 3) Only happen when the car is warm up. FYI, the rough idle doesn't happen all the time. Again, I had EAS run both actuators and they are in good shape (so i dont think is the actuators) got me look into the MAP Sensor and the coil packs, I had the spark plugs change about 5 to 6 month ago but didnt change the coil. this car does not have MAF sensor.. so i cannot think anything else relate to current symptom I am having. |
02-06-2018, 03:32 PM | #11 | |
Rep 3,737
Drives: 2018 M2
http://www.m3post.com/forums/showthr...el+purge+valve heres one long post where everyone assumed it was the ICV and it turned out to be an $80 fuel purge valve |
Patrón544.50 |
02-06-2018, 04:54 PM | #12 | |
Rep 500
THANK YOU SO MUCH. Just order the fuel breather valve from ECS. I will give it try, I hope this solve the whole problem. |
02-14-2024, 05:42 PM | #14 |
Rep 933
Drives: E90 M3
Currently chasing this same symptom. It’s been on and off for a while, maybe happened once or twice a year now it’s about once a week. I’ve watched fuel trims, O2 sensors, vaccuum while driving home from work and nothing really sticks out when it starts. I have noticed it’s less severe in cold weather, probably due to denser air….amd it only starts when the engine is at temp. Mostly happens after I get off the highway and sitting at the next light. Then usually solid for a while, doesn’t happen every red light.
I’ve read another thread pasted below, seems like this problem has been around for a while. Only definitive solution was the fuel breather, which I was leaning towards because it acts the same exact way. https://www.m3post.com/forums/showth...1191775&page=2 If anyone has had success with this I’d appreicate any insight. A lot of parts were thrown at this issue by many people in these threads, most of which I’ve personally already done in the past 5 years just in maintenance. I purchased another fuel breather valve (replaced it a couple years ago when getting the stuttering after fill up). I may just try and see what happens. |
02-14-2024, 06:36 PM | #15 |
Rep 1,114
Drives: 2009 E92 M3 Dakar Yellow II
I've been told by two separate BMW techs to treat them as a wear item. Expect to change them periodically. Not sure of the mileage interval for failure though. Mine was changed at around 90K miles, still fine at 113K
Ajolives922.00 |
02-14-2024, 08:11 PM | #16 | |
Rep 1,486
Drives: 2012 e92 M3 DCT ZCP
02-15-2024, 12:56 PM | #18 |
Rep 478
I have these same symptoms and thinking I will do this. I have the plenum removed anyways to replace a few other parts so figured I might as well get this one done too. One question regarding the part - FCP euro sell this part made by Bosch for $48 compared to the BMW part that ECS sells for $110. Is this something I can go with the Bosch part or does it have to be BMW original? Not sure who is the OEM for this part anyways. Can someone please chime in?
Here is the link: https://www.fcpeuro.com/products/clo...SABEgJIT_D_BwE Last edited by M'EM; 02-15-2024 at 12:58 PM.. Reason: Link to the part |
02-15-2024, 02:49 PM | #19 | |
Rep 933
Drives: E90 M3
