R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      03-02-2018, 10:39 AM   #1
MetalsMan
Drives: 2015 Mineral Gray M3
GC Camber Plates/KW H.A.S Combo Noise Question
Good Morning Gents,
I installed some GC Camber Plates and the KW H.A.S. Springs on my F80 a few months ago. If anyone has questions about install, and the setup, please feel free to ask.
For those with some experience, I'm getting some knocking noises over any small bumps at any speed and it's driving me nuts. Some say that's normal, while others report absolutely no noise whatsoever from their setups.
If everything is torqued down properly and the setup is under load, I can't imagine what would be making noise especially at low speeds.
Appreciate the feedback.
Thanks
      03-04-2018, 02:25 AM   #2
Circuit Hunter
Drives: F80 M3
Originally Posted by MetalsMan View Post
Good Morning Gents,
Thanks
I have the GC Camberplates and MPerformance HAS and I get some light chatter over sharp road imperfections at slow speeds. It can be annoying at times when the roads suck. I tried replacing the spherical bearings in the camberplates and it didn't help much if at all. I think it may be the nature of these camberplates because I've had two shops confirm everything is fine.
IG: @circuithunter
      03-04-2018, 06:28 AM   #3
ashmostro
Drives: 2020 M4cs | 2022 M550i
It’s normal, assuming you’ve confirmed the top nut is torqued correctly and your spherical bearing isn’t damaged.
The hard parts that are normally rubber in the OEM plate transmit noise that occurs between the spring and damper through to the chassis that would normally be damped out by those aforementioned rubber parts.
Price to pay for negative camber...
f80post
