03-06-2018, 11:13 PM | #1 |
Rep 402
Recommended Height For BMW M Performance Suspension (HAS)
What factors determined BMW's "recommended" height for the HAS, and what downsides are there (other than greater risk of scraping the front end) to lowering the car at the max HAS level? Are the handling and suspension unbalanced when doing so?
2018 Atlantis Metallic M3, Manual, 854 miles! - SOLD!
http://f80.bimmerpost.com/forums/sho....php?t=1510201 |
03-07-2018, 01:05 PM | #2 |
186
Rep 339
Drives: 07 e90 335i
Most likely shock travel/ tire clearance.
03-09-2018, 02:12 AM | #3 |
Rep 1,089
No, its the performance of the struts and coding. I put them all the way down and they rode like shit. I have them at min front measurement at 625mm all around which is gts street front and it's awesome.
03-09-2018, 02:17 AM | #4 |
Rep 402
So the awesome ride is higher than the BMW recommend drop?
03-09-2018, 11:20 AM | #5 |
Rep 909
I have had my car full drop front and almost full drop rear and the ride has been great.
03-12-2018, 05:28 PM | #7 |
Rep 1,089
Recommended height for 20s is 633/626mm or 24 7/8 / 24 5/8" from bottom of rim to fender.
Minimum is 350/325mm from center of rim to fender or with 20s 24.5/ 23.5" from bottom of rim to fender. GTS street height is 24.5/ 24 13/16" from bottom of rim to fender. This is why I did 24.5" f/r. Going below 24.5" rode like shit and was clearly under damped no doubt it will eat the shocks going below min range. I've experienced this before with pss9s. |
karbonM330.00 JohnBayArea7.50 |
03-17-2018, 08:44 PM | #8 | |
#LSBM3
1423
Rep 1,973
Drives: 2016 BMW M3
Garage List 1984 BMW R65 [0.00]
2020 Ford F-150 XLT ... [0.00] 2003 Mitsubishi Evo ... [0.00] 2016 M3 Competition ... [10.00] |
/// M3 |
03-17-2018, 09:49 PM | #9 | ||
6586
Rep 5,305
This doesn't work on different diameter wheels though. That's why I prefer measuring from the center of the wheel to the fender. |
Kiko_f8043.50 |
03-18-2018, 10:04 AM | #10 | |
#LSBM3
1423
Rep 1,973
Drives: 2016 BMW M3
/// M3 |
dpgfunk332.50 |
03-19-2018, 11:12 PM | #11 |
Rep 909
My guess is wheel well clearance plays a part in that recommendation. The kit can be adjusted outside of the "recommended heights" but they did not design the kit to be able to be set in a manner that would damage the car (look how conservative the front max drop is). If you go lower than the recommended height, there is a chance that your wheel can rub the wheel well during turning especially if there is a bump, and even more likely if you have wider tires than OEM. This can rub a hole into the wheel well which also protects one of the radiators from debris.
04-16-2018, 04:01 PM | #12 |
Rep 1,089
If you look at the BMW instructions, all of the measurements are from the bottom of the rim to the fender.
F80 M3 HRE FF04 275/305.
04-16-2018, 04:02 PM | #13 | |
Rep 1,089
This is exactly right. That's why the BMW instructions given different recommended heights for the different size rims. If you do the math they're the same just take up the difference from rim size. I did the math for you on 20s.
