04-04-2018, 07:01 PM | #1 |
Rep 9
Ride height
I recently installed KW suspension and they've installed it in a way that front axle is around 10mm higher than the rear (610 mm rear, 620 mm front). However when i looked at GTS settings for track i've noticed they've set it up this way:
Correct me if i'm wrong, but it looks like the rear is higher than the front. I mentioned this to the guy who installed the suspension and he told me it would mess up the center of mass in the car if i lifted the rear higher than the front. Soon i'll be changing the car suspension setup for track and i don't know if i should leave the car height the way it is or go closer to GTS settings and lift the rear. Is this normal that the front is higher than the rear? |
05-01-2018, 02:38 PM | #2 |
Rep 1,089
It is. The stock m3 is higher front, GTS higher rear. I set mine equally. Search my posts about this. I discussed it extensively.
F80 M3 HRE FF04 275/305.
04-30-2022, 03:58 PM | #3 | |
Rep 69
609 and 619 measured from where ? The GTS has 19" front rim and a 20" rear rim. Are these measurements from the bottom of the rim to the fender ? Is this 609mm from the bottom of the rim to the fender?
2016 M4 ZCP - ARM Downpipe, KW HAS, Bootmod3 |
CanAutM321116.50 |
