05-03-2018, 12:52 PM | #1 |
Rep 97
Rear wheel fitment | Camber | Rubbing issues
What's up folks,
Here's the issue. I finally received my Brixton's CM10 in 20x9.5 ET18 / 20x11 ET35, and I originally was running the recommended 265/30/20 front 295/30/20 rear, Michelin Pilot Sport 4S. I'm lowered on H&R Sport springs with OEM struts seeing I have the adaptative suspension. After doing a bit of research, it seems like the H&R are on the soft side. Basically, the issue is that I kept experiencing rubbing on the inner part of the rear bumper, even after two alignments to play with the camber. My tech told me the best he could do in terms of camber is 2.4, then the toe would be off. There's no way in hell I'll deal with rubbing, so I got 285/30/20 right away not to jeopardize the tire wall. The 295 / 285 pictures are attached. Obviously, the 295 look much better, but there's no way I'll deal with rubbing. Basically, I'm looking for all the options possible that aren't "Get KW V3's" seeing I'm located in Montreal and drive the car year round. Change the H&R springs for Macht Schnell? Are there rear camber plates / toe adjustment options, and who's running it? What are the lowered on spring alignment specs I should try to get? Should I simply run the 285 and movement on? All comments are more than welcome |
05-03-2018, 01:10 PM | #2 |
6580
Rep 5,304
295 looks better for sure. If you want to dial in more negative camber on the rear wheel while retaining usable toe settings, you need to get some toe links. The good thing is that these are relatively inexpensive, easy to install, and your alignment guy will thank you for it.
As far as H&R goes, you'd do well to replace them with anything; literally, anything else. H&R springs with OEM shocks run like shit. |
05-04-2018, 01:15 AM | #3 |
Rep 268
^Agreed. HR sport springs are known to be soft as tofu. Their springs also drop your car more than others so not surprising you are rubbing.
I'm running swift springs on 20x11 et37 with 295/30 PSS no rub. Camber is set -1.8. Hope that helps!
2016 Alpine White F80 | Individual Opal Interior | BBS LM-R | Dinan Exhaust | Active Auto Midpipe | V-Style Lip | Vorsteiner Rear Diffuser | M-Performance Spoiler | IND Alpine White Grills | Swift Springs | Instagram: S55Journal
05-04-2018, 05:16 AM | #4 |
21117
Rep 20,741
Drives: 2021 911 turbo
ET35 is too aggressive for meaty tires. Apex did some extensive testing and figured ET44 to be the ideal offset to fit the widest possible tire wthout rubbing.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
M3_JT16.00 |
05-04-2018, 05:31 AM | #5 |
Rep 488
Have you checked what is actually rubbing? Is it the metal fender or the fender liner? If it’s the fender liner, and you are ok with it, you can either let it rub through or trim it.
Although 20x11 ET35 is about 5mm too aggressive, I’d be shocked if you were hitting metal while “only” running a 295. Good luck. |
M3_JT16.00 |
05-04-2018, 07:43 AM | #6 |
Rep 97
Here's the part where its rubs, it's actually on the bumper and not on the fender. If you look closely to the picture of the inside of the fender / bumper, you see where it thinned.
I'm very aware +35 on a 295 is agressive, but I also see a lot of the fitment-oriented guy (dubsesd for instance) running much more agressive setups such as 305/30/20 on a 11.5" wheel with a +37 ET. I think the problem really is with the H&R - to add to the picture, it looks like the rear passenger side is even lower than the driver's - I'll add the pictures from both sides so you can compare, pay attention to the Michelin logo. Last edited by M3_JT; 05-04-2018 at 07:50 AM.. |
05-04-2018, 07:54 AM | #8 |
Rep 97
Keep in mind this is for every day driving, and because I love the look of it. When I go to Tremblant, I obviously run a different setup...
05-04-2018, 08:45 AM | #9 |
Rep 488
The passenger side is always lower on these cars. FYI the 305 guys run a 25 series tire. The overall diameter of the rear is making the offset a challenge. From the looks of it you may need to stick with the 285 rear or change springs to something with less drop. Although with your car full of passangers you may experience the same issue as your are now.
05-04-2018, 08:55 AM | #10 | |
Rep 97
I'm definitely planning on changing the springs, I'm going with Macht Schnell, which gives a smaller drop in the rear and will be stiffer than the H&R. I'll also add adjustable toe links to add a tad more camber (if required) - I feel that a -3° (compared to the -2.4 I have right now) would fix the problem. It's really a matter of fine tuning at this point, but I'm OCD and I want to find a solution |
05-04-2018, 09:03 AM | #11 |
Rep 488
Good luck. I don’t have experience with rear toe links with the two lowered F80’s I’ve owned but if they can get you said camber it may save you from needing a spring swap. With that being said a firmer spring should add performance unlike the H&R. I’ve been very happy with the Mperformance.
M3_JT16.00 |
05-04-2018, 09:10 AM | #12 | |
Rep 97
Thanks! |
05-04-2018, 09:56 AM | #13 | |
Rep 39
I'm on swifts and my wheels are Signature SV104 10.5 ET 32 in the rear with pilot 4s |
05-04-2018, 09:58 AM | #14 | |
Rep 97
05-04-2018, 09:59 AM | #15 | ||
Rep 39
M3_JT16.00 |
05-08-2018, 08:56 PM | #16 |
Rep 4,107
I'm really supriced the tire is rubbing.
I'm running 305/30 on a 12"... Had some issues on the inner fender but it's fixed now... Btw... F80/F82 fitment isn't the same anyway... https://ibb.co/cTLBW7 |
M3_JT16.00 |
05-08-2018, 09:35 PM | #18 |
Rep 97
05-08-2018, 09:56 PM | #19 |
12
Rep 28
I got a f80 m3 on Vorsteiner VFF102 20x10.5 +35 and 295/30/20 tires with Siwft spec R springs.
Im rubbing on the back when i go on uneven surfaces or sudden dips on the road. -2 camber on the driver side and -1.54 on the passenger side and both sides rub. |
05-08-2018, 10:01 PM | #20 |
Rep 97
I barely rubbed on the passenger side with a -2.4 camber on 11" ET35. I'm sure I'll fix it with adjustable toe links and a tad more camber, the 295 just look way too good not to do it.
05-09-2018, 01:38 PM | #21 | |
Rep 268
