05-19-2018, 01:56 AM | #1 |
Rep 101
My car broke.
I just purchased the car 700 miles ago and ~20 days. Fortunately I purchased a warranty that has immediate coverage and it will be towed to service on Monday.
I have driven the car a little rough but nothing major. I pulled up to a stop sign and my car just shut off. Prior to this it was running completely fine and I had driven all day. The car would start for 10 seconds and then die and the whole time it had a super rough idle. I was able to get it started long enough to get it to my house 1/10 mile away. I started it this morning and just straight gasoline smell with white smoke billowing out of the exhaust big time. After I turned the car off the white smoke was still coming out of the exhaust for a while. It is also showing drivetrain malfunction constantly and running like garbage. I know my car is getting looked at Monday but I'm just curious as to what this could be? It's a 2013 DCT with 41k miles.
2013 Black Sapphire Metallic, Sakhir Orange Interior, DCT
05-19-2018, 10:08 AM | #2 |
Rep 881
I had a lot of white smoke from my exhaust, drive train malfunctions, misfires on either side banks....and car suddenly died while driving slowly through my neighborhood; luckily couple blocks from my house.
Turned out it was my in-tank low pressure fuel pump failing. Had it replaced along with EKPS unit and everything is right again. |
05-19-2018, 12:36 PM | #3 | |
Rep 101
05-20-2018, 07:19 AM | #5 |
Rep 101
No, I had it shipped in from Little Rock, AR.
05-20-2018, 06:00 PM | #6 |
Rep 76
Same thing happened to me 2 years ago right after pulling out of the dealership,turns out to be high pressure fuel pump failing.BMW replaced all injectors on bank 2 and high pressure fuel pump.
05-21-2018, 11:03 PM | #8 |
Rep 101
My SA said it definitely sounds like a fuel problem and is probably an injector or the fuel pump. I will hear more tomorrow morning.
05-21-2018, 11:04 PM | #9 |
Rep 101
It has 343M wheels and is not tuned to my knowledge.
05-22-2018, 02:07 PM | #10 |
Rep 79
Had the same exact thing happen to me during a run at an 1/2 mile event. turned out it was an injector and got the whole bank replaced along with the cat on that side from being drenched in fuel.
05-23-2018, 08:37 AM | #12 |
Curve Thrasher
623
Rep 3,773
Would this be a beware of buying this car you are talking about so I can warn my buds who might want to get a car from them
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run |
05-23-2018, 01:46 PM | #15 | |
225
Rep 553
So long but someone bought it recently thought that might be OP. |
05-23-2018, 01:47 PM | #16 |
225
Rep 553
I knew it would be injectors. Maybe your car was sitting for a while as well ?
In any case glad you got it taken care of under bmw warranty. Do u have a aftermarket one too? |
05-24-2018, 07:58 AM | #17 |
Rep 101
Yes, I have an aftermarket warranty as well. They would've covered the repair had I not called BMW USA to ask about the injectors and see if my vin was apart of the extended injector warranty. My SA had no idea.
