R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      05-19-2018, 06:11 PM   #1
slaughter.mode
slaughter.mode's Avatar
Drives: 2018 M4 Competition
2018 BMW M4 ZCP  [9.80]
RESOLVED: Steering Clunking/Popping Noise?
I've seen many posts with a lout popping/clanking noise but this is a more subtle sound that seems to be originating from the center of the steering rack. I can hear it when stationary or reversing slowly. I don't hear anything while actually driving (I think). I even threw the car on an alignment lift and confirmed it's coming from the middle. Perhaps I'm having OCD or there's something up with the new spacers I installed but is this sound normal? It sound much more pronounced inside the car. The techs at my shop think it's the steering rack as well.
Update 6/4/18 > Still an issue, and it has turned into a popping/clunking noise from inside the vehicle. The clicking is still there as well but quieter (due to loosening and re-tightening the strut clamps under load).
Update 6/6/18 > Issue resolved.
They re-installed everything, replaced the following bolts (again) and also replaced the upper "hats" for each strut. Shop said they had extra brand new ones. I'm almost certain that was the golden ticket but who knows.
07-11-9-905-418 HEX BOLT WITH W 2
33-32-6-768-884 HEXAGON NUT WIT 4
34-33-9-806-226 NUT, SELF-LOCKI 2
33-32-6-760-668 SELF-LOCKING CO 2
07-11-9-905-610 HEX BOLT WITH W 2
31-30-7-854-446 GASKET 2
31-30-7-855-400 HEXAGON SCREW W 10
33-52-7-850-600 12-POINT NUT 2
      05-19-2018, 09:30 PM   #2
knightarmor
855
Drives: 2017 M3
Did you recently get your suspension swapped? That sounds like the strut clamp bolts on the spindle aren't properly torqued.
      05-20-2018, 09:32 AM   #3
slaughter.mode
I did but the noise didn't start until I installed the spacers. Took off and re-torque the wheels a few times to ensure they're sitting perfectly.
We did dive underneath the car yesterday and there's no noise coming from the sides, just the middle. I'll double check those, though. Do you know the proper torque spec?
      05-20-2018, 02:46 PM   #4
knightarmor
855
Drives: 2017 M3
From the Salt City Euro's DIY link
Specs and Bolt Information:
Front Suspension:
Plastic Shroud Bolts - 10mm - ¼ Turn
Carbon Brace Bolts - 13mm - 12 ft.lbs.
Carbon Brace to Coolant Tank Bolt - 10mm - Snug
(A) Aluminum Brace E-Torx Bolts - 9mm - 25 ft.lbs.
(B) Aluminum Brace E-Torx Bolts - 10mm - 30 ft.lbs.
(C) Aluminum Brace Cowl Bolts - 16mm - 35 ft.lbs
Strut Hat Bolts - 13mm - 25 ft.lbs.
Strut Spindle Nut - 18mm-12pt - 25 ft.lbs.
Strut Pinch Bolts - 16mm - 60 ft.lbs.
Sway Bar End Links - 16mm/T30 - 44 ft.lbs.
Headlight Leveling Sensor - 10mm - Snug
Rear:
Lower Strut Bolt - 18mm - 74 ft.lbs.
Eccentric Bolt - 21mm/18mm - 74 ft.lbs.
And a link with the same noises and solution.
http://f80.bimmerpost.com/forums/sho...1402135&page=2
I actually hear this noise on mine when I bring the car down on the lift.
      05-20-2018, 09:03 PM   #5
slaughter.mode
Front Suspension:
Rear:
Very helpful. Interesting, is it just a nuisance or something to be concerned with?
      05-22-2018, 01:23 PM   #6
knightarmor
855
Drives: 2017 M3
It's def. a nuisance. I heard it the first time I brought the car down off the lift after doing the M Performance coilover install. You can clearly hear it when you loosen and tighten the pinch bolt nuts on the vehicle. I loosened and retorqued the nuts and I haven't heard it while driving but as I said I do hear it when the suspension is re-compressed after being fully extended on the lift. I'll probably have the car up on the lift in a few days, if I remember I'll take some video so you can hear it upon compression of the suspension.
      05-22-2018, 01:30 PM   #7
slaughter.mode
Awesome. I have a really hard time trying to pin point the sound with my single jack. It sounds like it really is coming from the steering rack (middle). Can i loosen/re-torque it with the wheel off or will that defeat the purpose since it's not under load? I guess I could order some race ramps...
      05-22-2018, 07:14 PM   #8
gunsmoker
Drives: 2016 M3
I had the same recently and the dealer changed the driver side strut and a few other bits and pieces and the noise went away.
      05-22-2018, 07:37 PM   #9
slaughter.mode
Was your car lowered or stock?
      05-23-2018, 05:45 AM   #10
gunsmoker
Drives: 2016 M3
stock, with 7000 miles on it. 2016 model.
      05-23-2018, 08:17 AM   #11
slaughter.mode
Oh! Ok. Mine had no issues stock, this just started after lowering, unfortunately.
      05-23-2018, 12:49 PM   #12
knightarmor
855
Drives: 2017 M3
Yea I preloaded mine (albeit not the best way) just putting a jack under each tire and then torqueing the nut while the car was in the air on the lift. Everything feels tight in the steering. Like I said though I don't hear it when driving so it doesn't bother me.
      05-23-2018, 01:03 PM   #13
slaughter.mode
Yikes, OK. I'll try this out! Hopefully I do not get crushed. 60lbs here we go. Oh and did you loosen and turn left/right first then tighten or just simply loosen + tighten (all under load)?
      05-23-2018, 02:07 PM   #14
knightarmor
855
Drives: 2017 M3
I def. don't recommend doing it this way if all you have is jackstands and a jack! I would go for some ramps first but you'll need to make sure you can actually access the fasteners without too much trouble.
I only loosened the nuts then retorqued. I did not turn the wheels.
      05-23-2018, 03:15 PM   #15
slaughter.mode
OK lol, I'll order ramps before I kill myself. The nut I'm guessing is facing the front per the video I reviewed so I should be able to get it done on ramps.
Thanks so much!
      05-26-2018, 03:54 PM   #16
slaughter.mode
Well, I got the car on ramps under load and loosened tightened the strut pinch bolts (16MM on passenger side and 17MM on driver side) and re-torqued to 60lbs...no dice, click remains.
      05-26-2018, 11:19 PM   #17
4DRS55
Drives: GTF80,718GT4,TVG80,G05X5
Did you try to remove the spacers and see if the noise is still present?
I would try to bring the car to the dealer and see what they say. I think they have a sib for this noise. Also If it sounds like it’s coming from the center it may be the bolt on the rack that may need to be snugged, but I would let the dealer do that and try to chase the noise down.
      05-26-2018, 11:33 PM   #18
slaughter.mode
I would try to bring the car to the dealer and see what they say. I think they have a sib for this noise. Also If it sounds like it’s coming from the center it may be the bolt on the electrical rack that may need to be snugged, but I would let the dealer do that and try to chase the noise down.
Yep, I'm over trying to figure this out. I will pull the spacers and give it one more test and if no change, I'll pull all the spacers off and take it in.
I may also remove the stud conversion too, not sure if they'll ruin my $460 titanium studs or not by putting a gun to them or trying to over-torque them to factory spec.
Update, pulled spacers, no difference. Car going to dealer tomorrow. I do wonder if it's the stud conversion...but I'll let them take a peek assuming a stud conversion will not mess with warranty.
      05-30-2018, 10:27 AM   #19
madnessm4
Drives: BMW M4 2018 ZCP DCT
I've had the same problem, had the dealer replace my lower steering shaft and the click went away, my click was a little bit louder and more pronounced. Noticed it after I unfortunately hit a bad pothole so I am assuming that must have been the culprit.
      05-30-2018, 10:31 PM   #20
slaughter.mode
Interesting. Well they've now had it for 2 days so hopefully they're doing work and sorting this all out. I had the car on an alignment rack above me and it really did sound like it was coming from the steering assembly but we'll see...
      05-31-2018, 04:30 PM   #21
4DRS55
Tell them to look into steering rack mounting bolts.
You can pm me if you have any questions.
      05-31-2018, 04:31 PM   #22
slaughter.mode
They refused. They said since they didn't install the MPHAS kit they refuse to look at it and indicated there's something wrong with the suspension, perhaps the way the spring is seated, etc. No details or specifics. Sigh.
f80post
