06-29-2018, 01:21 PM | #1 |
Rep 3,056
Spacers with MP HAS
I run stock 19s with stock tire size (PS4S).
I had them drop me to recommended height yesterday. I want to add spacers, and was thinking 12 mm all around. Will it rub? What spacers are you guys running with stock 437's?
Fire Orange 6MT G80 (Miss July, 2021 Cover of Bimmerpost)
SMB M3 CS (gone) YMB F80 6MT (gone) |
06-29-2018, 01:24 PM | #2 |
BimmerPost Supporting Vendor
8215
Rep 18,823
Drives: BMW
15F/12R is recommended for your setup. Brings the tires flush with the fenders.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
06-29-2018, 01:26 PM | #3 |
Rep 3,056
thanks tom! Without rubbing? Can you PM me pricing on Macht Schnell?
06-29-2018, 01:27 PM | #4 |
8215
Rep 18,823
Drives: BMW
No rubbing under regular driving, its a very common setup. PM incoming.
06-29-2018, 01:32 PM | #5 | |
Rep 3,056
Would it be wise to go 12F/10R to be safe?
06-29-2018, 01:37 PM | #6 | |
8215
Rep 18,823
Drives: BMW
Just matters on your level of OCD, most choose the 15/12.
06-29-2018, 02:31 PM | #7 |
Rep 3,056
I run 640M (18" M winter wheel package) during the winter. will this work with that as well? Thanks Tom!
06-29-2018, 02:33 PM | #8 |
8215
Rep 18,823
Drives: BMW
As long as you are running stock tires, no problem.
06-29-2018, 02:36 PM | #10 |
Rep 3,056
How so? I was a suspension newbie until, oh, about 5 hours ago lol.
06-29-2018, 03:35 PM | #11 |
Rep 4,983
The spacers push your wheels out, hence they stick out more. All those rocks and pebbles that once harmlessly hit inside your fender, well now some of them escape and hit the side of your car (especially the rear fender, thank you extra PPF).
07-02-2018, 07:57 AM | #12 |
Rep 3,056
Interesting..Would have never guessed.
07-02-2018, 08:11 AM | #13 |
Rep 3,056
Do you find they impact the driveability in any way?
07-02-2018, 09:50 AM | #14 | |
Rep 4,983
07-21-2018, 08:34 PM | #15 |
IG @bmwF9xG80
3813
Rep 7,593
Drives: G80 M3, X4M, G07 X7m50
frankiebones im on KW HAS, 437M 255/35-19 front 285/35-19 rear no spacers
What Jockey is saying was very noticeable with 20's when I was very low on KW HAS, after increasing to 0.5 front 0.2 rear it has improved but will raise front a bit more since it seems the 19s are kinda tight when turning in parking and driveway still an issue 80%
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
03-21-2022, 09:03 AM | #16 | |
Rep 2,053
If I have an oem suspension car then add MP HAS onto it, not at the lowest setting, but about halfway down; and a 5mm spacer up front. Can I run stock 437s without rubbing/binding? Rubber would be RE71R in 265/285-35-19. I had to run a spacer after lowering the car on my aftermarket wheels for clearance, but the 437s are needed for an hpde event upcoming. appreciate your time! -RB
Moved to the darkside: '23 718 GT4; 11-10-2022.
Le Mans Blue F80 - Munich 5-22-2015 / US 7-7-2015 / SOLD 9-17-2022 ED RecapArctic Grey G05 - Spartanburg 8-29-2019 X5 PCD Recap |
03-21-2022, 01:13 PM | #17 | |
8215
Rep 18,823
Drives: BMW
03-21-2022, 08:45 PM | #18 | |
Rep 1,415
RowanBuds1707.00 |
03-21-2022, 09:13 PM | #19 | |
Rep 2,053
Appreciate the reference, I'm just going to be fingers crossed for now- will swap . No idea what comparable new rubber I can even source at this stage in the game, as RE71 is NLA, MPS4s I'll destroy in a weekend...we'll see I guess.
03-22-2022, 06:35 PM | #20 | ||
Rep 2,053
Either way I'll have to figure out a solution asap as the RE71s will be done for after this event if I make it. May just not be worth it to stress trying to figure this out before the weekend I'm trying to make.
