07-27-2018, 07:59 PM | #1 |
Rep 2,799
Best Rock chip repair
What's the best way to get rock chips repaired without getting it painted? I know about touch up paint and dr color chips , can A body shop just sand and fix the rock chips only without painting the whole area ?
2021 M2C HS/6MT/Exec/Moonroof
07-27-2018, 10:18 PM | #2 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
Yes, but it takes a lot of time and skill and will still not look perfect; thus many (? most) body shops don't do it, especially with the availability of Dr. ColorChip, etc. The old fashioned way is to build the paint up one layer at a time (it takes a lot of layers + drying time) until the paint is above the chip, then wet sand, then polish then apply the clear coat (if using). Did I say it take a lot of time?
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
07-29-2018, 08:34 PM | #3 |
Rep 2,799
The color code description for my car in dr colorchip website shows as Light blue metallic, my car is Mineral grey metallic with B39 code, is that safe to buy?
07-30-2018, 08:19 AM | #5 | |
Rep 2,799
I called them and they fixed the description.
07-31-2018, 02:17 PM | #6 |
Rep 1,001
Dr. Color Chip works great. I used it extensively on my old "World Rally Blue" WRX that had road rash from hell. It's not perfect and you can spot it if you look close, but it's worlds better than having the primer show through.
It's also pretty easy to use if you take your time and follow their instructions.
boss2k1090.00 |
08-23-2018, 10:57 AM | #7 |
Rep 2,799
Can you tell me if this is a good repair done by me as its the 1st time i used dr color chips repair and not very good at these things
1st pic -- Before repair 2nd pic -- After repair Pics were taken from 6-8 inches from car, its less visible if u stand 2 feet away
damageprone580.50 |
09-02-2018, 03:31 PM | #8 |
Rep 6,863
Looks ok to me. That's been about my experience with dr colorchip, it fills in the chip and certainly does not look perfect but it is much less glaring than seeing through to the plastic/sheet metal. From a few feet away it's almost unnoticeable.
boss2k1090.00 Poiseuille5392.50 |
09-04-2018, 10:21 AM | #9 | |
Rep 3,737
Drives: 2016 M4 DCT Tanzanite/Amaro
Comments by others that a competent body shop could produce equal results are correct. I choose to have my installer do this only because I saw multiple examples of his work. |
09-04-2018, 10:50 AM | #10 |
Rep 5,733
Drives: '24 iX50; '23 i4 M50
^^Thanks...I've been meaning to purchase some Tanzanite Blue Dr. ColorChip to repair various chips from an overzealous PA plow truck operator this past winter when he had his salt spreader set ridiculously way too high and it showered down on me!!! I was fing livid to say the least!!! Good to know the color matched well. I never used the stuff before.
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
Poiseuille5392.50 |
09-12-2018, 09:38 AM | #11 | |
Rep 3,737
09-12-2018, 01:30 PM | #12 |
Rep 5,733
