08-25-2018, 01:10 AM | #1 |
Rep 659
Stek Full front PPF done but found many debris
Hello,
I picked up the car today and while I was inspecting the PPF, I realized two things. The first picture is the side mirror that Stek film was installed and I was wondering if this how the normal pre-cut looks like after the installed? For those with Stek PPF installed on the side mirrors, does it cover the entire mirror or looks like this? Secondly, Is it normal to have about 10 debris under the film ? (mostly found from the front bumper areas) I already informed about this debris to the shop and the installer told me that after 2 weeks, they will inspect the car and re-do the film. I know this can't be perfect, but found too many... I also found one big bubble on the hood and other on the front bumper. Does it go away by itself? Let me know your experience with your PPF! Thanks! Last edited by M3nmotion18; 08-25-2018 at 01:29 AM.. |
08-25-2018, 01:57 PM | #2 |
Rep 180
I have had PPF installed on previous vehicles. The debris, especially what you have in the second pic is not normal and I would want it fixed. With regards to the pre-cut mirror, my opinion is that it looks amateurish but I do not know if this is because of the precut pattern or because of the installer. I think it could have been done to appear much less noticeable.
08-25-2018, 09:01 PM | #3 |
Rep 3,286
Drives: 2002 M5;2007 M Coupe;2020 M2C
While one or two tiny pieces of debris may be okay, if in an area not visible and if not forming an air pocket, the one you picture should definitely be fixed by the shop. it is large, visible and forms an air pocket.
In terms of bubbles, small ones will resolve, so it depends on the size. There is definitely a seam on the mirror for all kits given the bend. However, the seam on your mirror seems quite noticeable (perhaps it is the lighting). For contrast, here is my mirror: GL
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel 2007 E86 Z4M Coupe Silver Gray/Black 2021 Kia Telluride (hauler) |
08-25-2018, 09:54 PM | #4 |
Rep 924
Sloppy work...
That mirror job is horrible and I would ask to have it redone along with the panel with debris. The mirror kit for our cars has that pattern, but the seam should be stretched to wrap to the underside of the visible edge. It looks like a sloppy alignment along with a dull blade on their plotter which resulted in a harsh edge that clearly shows that it was not properly sealed. The white visible edge should not be there. That is adhesive left behind from not having sealed with 70% IPA a bit of heat.
Waiting two weeks should not be necessary for this, but keep in mind that it is normal for some cloudiness or even small bubbles to dry out as the sun sets the film. Especially on darker colored cars. This is why most shops will not perform rework until the film has set for at least two weeks.
2018 M3 ZCP Glacier Silver Individual Mugello/Black Bicolor Leather
2018 BMW R1200RT Ebony Metallic (my daily) 2016 M3 Silverstone on Black 6MT (SOLD) |
08-26-2018, 02:07 AM | #5 | |
Rep 659
If you look at my mirror, film is not even covering the entire mirror.. When the detailers are done with PPF, don't they inspect the car to make sure the obvious debris are not there? They had my car for 4 days. |
08-26-2018, 02:15 AM | #6 | |
Rep 659
08-26-2018, 02:31 AM | #7 | |
Rep 659
FYI: I did the full frontal plus CF roof at a highly recommended detail shop! Last edited by M3nmotion18; 08-26-2018 at 02:51 AM.. |
08-26-2018, 02:39 AM | #8 | |
Rep 659
08-26-2018, 02:46 AM | #9 |
Rep 659
One more thing I discovered about PPF on the sensors:
PPF was covering over the two sensors where the camera is on the each side. However, PPF was cut where the sensors on the front bumper areas. Is this how the Front bumper PPF was designed when it was pre-cut? Thanks! |
08-26-2018, 06:29 PM | #11 | ||
Rep 924
To me, that looks like it could be ceramic coating that was not properly buffed out or they wiped that area with a dirty towel that had ceramic coating residue on it. I would think that if it was residue from shipping film, the coating installer would have caught it, but then again, the film work doesn't appear to have been done correctly. What does it feel like to the touch? It should buff out with careful paint correction and re-coating. If I were you, I would bring the car back and make sure they at least document all of this before too much time goes by and they try to blame this on something else.
08-26-2018, 06:37 PM | #12 | |
Rep 659
I used the microfiber towel to try wipe them, but it doesn't come off. I think they should buff out and re-coat that portion. |
08-27-2018, 09:51 AM | #13 |
Rep 546
coating high spots need to be knocked down with a polish/compound and recoated.
the mirrors look to be mis-aligned and crooked. redo. the kit will sit a tad off the edge. You cannot have the film perfectly in line with the edge, it will lift in a matter of time. If you cant wrap it around, it needs to be trimmed back a tad accordingly. Looking at Kevin's mirror, while the top looks like a tighter fit, the bottom base of the painted part is way off. the installer needs to find the happy medium point. If you dotn want to see that big of a gap, a custom one piece is doable. dirt under the film, address this one and come up with a solution you are ok with. Nothing is 100% debris free. But, that one looks to be big...might be soap scum build up from the bottles, or possibly even broken and balled up adhesive during the install. We had that happen before with Stek and suntek and Xpel. Last edited by Eric S; 08-27-2018 at 10:04 AM.. |
08-27-2018, 08:40 PM | #14 |
Rep 5,316
Drives: G80 M3 6MT
Dude if that line is really where your installer cut the mirror up to, then just run away from this place. They suck. That cut on the other mirror looks like garbage and it looks like your PPF is almost 1/4 of an away from where it should be on the photo I attached. That combined with what appears to be a coating high spot tells me that whoever did this work has no real idea what they're doing.
Scott, Partner
Insight Automotive Consulting Click HERE for all discounted BMW New Car Pricing Click HERE for all BMW In Stock Inventory Specials Call/Text: 516-416-5481 Email: scott@insightautoconsulting.com |
08-28-2018, 08:11 AM | #17 | |
Rep 257
stek
Many people will comment without the prior knowledge of what you agreed to. I am not saying that you agreed to having a kit mirror or not, but for another person to call that out as wrong, well, its wrong on their part. Bruce |
08-28-2018, 10:19 AM | #18 |
775
Rep 1,751
Wrong. A place with any respect for their own company should have some standards of the quality they produce. Too many place do awful work and they shouldn’t be in business but in today’s world we give the benefit of the doubt and second chances. This place should be run out of business for this work.
smithf802808.50 |
08-28-2018, 05:57 PM | #19 |
Rep 546
WHOA...that's a bit harsh don't you think WreckedmyF80?
The shop is removing and redoing just as the owner wanted. In the end, happy owner, happy shop. If anything or anyone in the world is perfect, please show me what or who, I'm yearning to see it... |
08-28-2018, 06:32 PM | #20 |
Blocked from G80/G82 for having an opinion
3498
Rep 3,729
Actually, he is right. These are some really obvious and sloppy mistakes. Any business that gives a damn about their work would have fixed it before letting it go out like that. These guys instead tried to pass it off and hoped the customer didn't notice so they could get away with their shoddy work.
smithf802808.50 |
08-29-2018, 08:05 AM | #22 | |
Rep 5,316
Drives: G80 M3 6MT
You see all the obvious mistakes and horrible lines here not to mention that horrible coating high spot. Would you ever let that leave the shop? Do you really think you could easily miss that stuff in a final walk over of the car? It's sad the car ever left their shop like this.
Scott, Partner
