10-27-2018, 10:35 AM | #1 |
224
Rep 382
Dust Inside Instrument Cluster
Does anyone have dust particles inside the instrument cluster? I see the dust particles behind the cluster in mine. I Just came back from the yearly service and the SA said that they can see it, but they can't do anything about it. Any clues if this is happening for others and if this is covered under warranty?
Thanks. |
10-27-2018, 01:00 PM | #3 |
driver
816
Rep 777
If you're out of warranty it's not hard to remove, open it up and dust it out
It's being held in by two screws on the upper side just bend down and you'll be able to see it -Lower your steering wheel as low as it can go -Remove those two screws up on top -Disconnect the 3 cables in the back and take out the instrument cluster (disconnect negative cable of battery in trunk first) -Plastic cover can then easily be removed There is a guide on here somewhere on how to do it. Look up instrument cluster overlays 10-15 min at most Good Luck |
whitstap79.50 |
10-27-2018, 05:57 PM | #5 | |
Rep 414
10-27-2018, 06:11 PM | #6 | ||
driver
816
Rep 777
