11-22-2018, 12:14 AM | #2 |
3138
Rep 2,953
11-23-2018, 11:59 AM | #3 |
BimmerPost Supporting Vendor
8250
Rep 18,839
Drives: BMW
Awron is not married to the vehicle's VIN, there is an optional flash for Delete-R and EVC controls if desired at an additional cost.
We have AWRON units in stock, ready to ship immediately. PM me when ready.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-24-2018, 11:02 PM | #4 |
3138
Rep 2,953
11-27-2018, 07:22 AM | #5 |
No 55mph
1622
Rep 8,476
Thru personal experience the Awron gauge is NOT VIN matched.
I purchased a slightly used one from the forum & installed in my F32 - no problems I don't see why the F8x gauge would be any different than the F3x...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
11-27-2018, 11:37 AM | #6 | |
8250
Rep 18,839
Drives: BMW
I don't see any benefit to going this direction, as the gauge doesn't operate different or take advantage of any new features. Luckily, we purchased a large stocking order and our current inventory does not have this firmware so displays can be sold/transferred without any additional cost.
11-29-2018, 06:35 PM | #7 |
3138
Rep 2,953
11-30-2018, 04:42 AM | #8 |
No 55mph
1622
Rep 8,476
No
I'm using the CGP VSC-1 to control exhaust flap thru programmed mirror button
11-30-2018, 07:05 PM | #9 |
3138
Rep 2,953
12-01-2018, 11:09 AM | #10 |
8250
Rep 18,839
Drives: BMW
EVC/DELETE-R is based off the device ID, not VIN.
12-04-2018, 08:53 PM | #11 |
3138
Rep 2,953
Sorry Tom, you know everything and anything without having to read. I forgot
I know that Awron's english isn't good, but can you clarify why the email says the display will not work on the new ECU without software reset? Inform me please as I do not know, nothing about device ID |
12-05-2018, 04:18 AM | #12 |
52
Rep 183
I like this. you 2 guys need to talk this out here. I am going to sit and watch. the winner will be known in about 2 weeks. I found a used one and we will see what happens.
12-05-2018, 12:28 PM | #13 | ||
8250
Rep 18,839
Drives: BMW
Every module (including DME) within the network has a Device (or hardware) ID. This has nothing to do with the VIN. The HVAC housing that Awron uses for their displays is a factory BMW part and will fit all 3 & 4 Series, including M3/M4. However, that's where the similarities end. Awron uses different profiles within the firmware for different vehicles: - F3x 3-Series, 4-Series (non-M) - F8x M3/M4 Once installed, the Awron display will look for the Device/Hardware ID of the DME in order to operate. If trying to install an Awron that was programmed for a F3x chassis into a M3 or M4, you will get a "incorrect chassis" error and the display will not operate. This wasn't the case a few years ago, but the change was made later when the F8x was released later on. If it works, you're lucky. Current production F3x (non-M) displays will not work with the F8X chassis - the hardware IDs between the vehicles are different. Awron can provide a firmware patch (at an additional cost) to provide compatibility. Awron (or EAS) will need to know the Awron serial (located both on within the setup menu and on a decal on top of the HVAC housing) for them to compile the upgrade, which can be upgraded within the USB cable from the display. The same upgrade is provided for those that want the Delete-R and EVC features - both at an additional cost. The Awron display does not marry itself to the vehicle's VIN and can be sold at a later date, provided it is installed into another car that shares the same engine/DME. Quote:
▀▄ eas | DIY: F8X M3 & M4 Awron DIY Installation Instructions https://f80.bimmerpost.com/forums/sh....php?t=1017936 Best of luck.
12-05-2018, 01:48 PM | #14 | |
3138
Rep 2,953
you are next level.
behindthen0thing839.50 |
12-05-2018, 02:24 PM | #15 |
No 55mph
1622
Rep 8,476
In my case when purchasing a used Awron; I knew that there are different P/N's for the gauge between my F32 and an M3 or M4 - therefore, I made certain the unit I purchased was originally for a F3x series and double checked the supplied P/N & Ser#
As stated, it worked perfectly for my F32 - confirming fact that they are not VIN matched, but are specific between ///M & non ///M models Hopefully Z33c made sure the unit he purchased was originally for a F8x series car...
12-05-2018, 08:11 PM | #16 |
52
Rep 183
came out of an m4 and is going into wait for it wait for it a big whopping M4 fingers crossed. I didn't mean to create a fire storm here. I just want to see if I could save a few bucks in my build. thank you for all the info guys. I will still let you know what happens when we turn it on????
12-14-2018, 07:05 PM | #18 | |
Rep 4,499
Have fun with it I know I did.
Have BT Tool professional, will scan and clear codes on your BMW. And now I am able to code my 2011 335is and M4
Link to my M4 euro delivery! http://f80.bimmerpost.com/forums/sho....php?t=1006526 Last edited by farbmw; 12-14-2018 at 07:20 PM.. |
12-14-2018, 07:17 PM | #19 |
3138
Rep 2,953
