Next Level Auto Brokers
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs)
      03-07-2019, 02:14 PM   #1
M370z
Drives: 370z
PPF main impact areas?
Hello! I just picked up my M3 CS today and want to throw some coverage on it. Would Bumper, partial hood, partial fenders, rockers mirrors and an extension of the rear film suffice? Or should I do more?
      03-07-2019, 02:22 PM   #2
Clark_Kent
Clark_Kent's Avatar
2228
Drives: Retired
I suggest searching the forums for this. This topic is probably the most discussed next to "Will x part void my warranty". Whether the thread was started yesterday or 3 years ago, the recommendations are always the same and the debate is always the same.
https://f80.bimmerpost.com/forums/sh...&highlight=ppf
      03-07-2019, 04:39 PM   #3
M370z
Drives: 370z
https://f80.bimmerpost.com/forums/sh...;highlight=ppf
Yep totally get it. My question isn't whether I should get PPF or which company I should go with, it is simply which areas I should cover (which none of those threads cover). That said, I will search further....
      03-07-2019, 06:01 PM   #4
Clark_Kent
Clark_Kent's Avatar
2228
Drives: Retired
Understood. If you read through the threads most discuss the coverage areas they went with and rationale in many cases. It's widely accepted to get as much protection as you're comfortable paying for. That typically entails the following: front bumper, headlights, entire front hood, side mirrors, a-pillars, leading edge of carbon fiber roof or entire roof, b-pillars, door cups, rocker panels, luggage kit for trunk lid and a custom piece (larger) of film replacing the factory film near the rear fenders.
      03-11-2019, 08:42 AM   #5
Eric S
Eric S's Avatar
293
Drives: in pre-order stages
The partials are a waste of time:
The line across the hood and fender will look hideous.
The paint will look/fade differently and it will be noticeable on the same panel
Your paint will accumulate rock chips just past the line, so you will kick yourself within 6 months.
In the end, you will have a protected front end, and then chipped up lower fenders and top of the hood, which will require repaint, rendering the partial on the hood and fenders pointless. Do the whole panel, or skip it and just do the bumper/headlights only
      11-19-2019, 06:09 PM   #6
papasmurf_m3
papasmurf_m3's Avatar
Drives: YMB F80 M3
This is helpful. I was debating myself what protection. But, my main concern was a horrible tan line on the middle of the hood and fender later. The expel installer was trying to convince me to do half the fenders and hood but, Ive now decided to stick to my initial gut feeling and do the front bumper and headlights.
Do you guys xpel the carbon fiber spltters?
60-130 mph 6.72 secs
1/2 mile trap speed 158 mph
ecutek - bend calibration pro tune - flex fuel - mpe - stock turbos - oem+
      11-22-2019, 01:09 PM   #7
Eric S
Eric S's Avatar
293
yes, ppf the carbon splitters.
Why would the guy recommend the partial? Makes no sense unless he is just in it for the quick buck...
      11-22-2019, 01:22 PM   #8
papasmurf_m3
Drives: YMB F80 M3
I’ve heard that it will last about 2 years with normal use. So likely will need to repeat the bumper. So I’m. It gonna stress too much about it.
The thing that bothers me however is I plan to black out the housings and our new lenses on but that might not be for a little while. I don’t want to drive around ra dog so I’m conflicted about protecting used headlight lenses that I will change at some point. I dunno 🤷🏻
      11-22-2019, 02:14 PM   #9
M 4 FUN
Drives: 320 Si, M4 comp. M3 E46
You should have PPF on everything you see when you are standing in front of the car, plus rear fenders. I did my whole car. It's black and it's the best thing i've done. I have Stek PPF film and it's self healing and very glossy so it's like putting on a layer of clearcoat on the whole car. It never needs polishing. Also headlights, A-pillars and at least front part of the roof is necessary to wrap.
      11-23-2019, 06:50 AM   #10
N54_BuiltE85
Drives: 335i and F80 M3
Agreed that half fenders and half hood will be cheaper but not worth it. The extra cost to cover the full part is def. worth it. Peace of mind and knowing the paint will age uniformly. I've heard that Xpel is the leading PPF provider. I currently have suntek on my F80 and have no issues.
      11-29-2019, 04:41 PM   #11
papasmurf_m3
Drives: YMB F80 M3
I was driving myself nuts overthinking, So, after the advice of the members here and talking with my installer.
Ive decided to go with front bumper headlights, hood, side skirts. the installer said he'd throw in the mirror covers. The rear fender flares already has a PPF cover the bottom half. So im going to leave that. Hopefully will be fine.
I figured I'll do the best I can with my budget, and in 2 years I'll cross that bridge.
      11-29-2019, 04:43 PM   #12
Andrae26
Drives: Sakhir M4
What shop are you going with?
      11-29-2019, 05:20 PM   #13
papasmurf_m3
Drives: YMB F80 M3
I went with http://california-motorsports.com/
f80post
