R44 Performance
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs)
      03-19-2019, 03:51 PM   #1
boglehead
Mechanical Engineer
boglehead's Avatar
94
Drives: '17 M3
Dremel to wheel hub/aluminum rotor body
So it did a great job on the center hub centric ring area that rusts up easily. However on the aluminum on the rotor housing it looks inconsistent. You can tell by the photos below. Just looks marked up.
I have tried:
- 000 Extra fine steel wool
- Dremel Carbon steel brush 428, 442 (does not last very long, brushes come apart)
Suggestions to blend in that rotor body a little nicer than it looks now?
Cheers
"It is not that we have a short time to live, but that we waste a lot of it. Life is long enough, and a sufficiently generous amount has been given to us for the highest achievements if it were all well invested..."
      03-19-2019, 05:20 PM   #2
Faceplant
Faceplant's Avatar
116
Drives: Yas marina f80
It’s gonna rust even faster unless you use some type of coating
What was the reasoning of doing this? That scars are deep, your gonna have sand them.
Idk how much material you took off but the rotors could possibly be unbalanced and cause a shimmy at speed
      03-19-2019, 05:58 PM   #3
boglehead
Mechanical Engineer
boglehead's Avatar
94
Drives: '17 M3
not worth it.
      03-19-2019, 06:09 PM   #4
MrSmartyPants
Drives: F80 M3 - 6MT_MW on SO
I'd bet sandblasting would leave a nice finish. Lots of work for removal, masking, etc. Though.
      03-20-2019, 08:31 AM   #5
Eric S
Eric S's Avatar
293
Drives: in pre-order stages
you need to spray that with something...like high temp satin color
or have it powdercoated or painted professionally
f80post
