10-22-2019, 01:57 PM | #1 |
Rep 948
Dyno Results
Had the M5 on the dyno today. My intention was to dyno both stock and stage 1 but due to misfires I was unable to run on stage 1.
Stock only for now, Stage 1 in few weeks once I've ironed out the creases. Results were pretty good, 567 HP and 558 ft lbs Torque. Let me hear your thoughts. |
10-22-2019, 02:01 PM | #2 | |
Rep 4,209
Drives: '13 F10 M5 | '15 F15 X5
10-22-2019, 02:04 PM | #3 | |
Rep 948
He used 4th I think. He didn't think his fans would cool the engine enough at the high speeds you get with 5th. If it wasn't kept cool enough then intake temps would rise causing the ECUs to pull timing resulting in less power. |
Ickdeep5720.50 |
10-22-2019, 04:52 PM | #4 |
811
Rep 1,847
With a stage 1 tune my torque curve was pretty much flat, not sure why yours is all over the place I would say the power is what you would expect for a stock car
What fuel were you running |
10-22-2019, 07:48 PM | #5 | |
Rep 1,064
Drives: i5 M60, M5's, 535.335, M550i
2013 535i M, Carbon black 20' 6 M wheels, totaled.
2018 750M , 2013 M5 , Individual Silver, Bolt ons-Straight piped 2019 M550 686BK Black Chrome 20"wheels, filters, Evolve Stage 1, Res delete 2024 i5 M60 Cape York Green |
10-23-2019, 01:48 AM | #6 |
Rep 948
Not sure, power seems to flatten off and the same time that torque drops, maybe he didn't have traction fully off?
10-23-2019, 01:50 AM | #7 |
Rep 948
10-23-2019, 02:46 AM | #8 | |
811
Rep 1,847
Mine is attached |
Ickdeep5720.50 |
10-23-2019, 02:48 AM | #9 |
Rep 948
10-23-2019, 02:52 AM | #10 |
Rep 948
Actually, look at your graph. It goes to 900 hp, mine only goes to the max output. Your torque drops like mine but looks less because of the larger graph. Your torque drops down to around 520 where mine drops to 470. An expected difference from stock to stage 1.
10-23-2019, 03:16 AM | #12 |
811
Rep 1,847
Not sure what you mean, my torque stays in growth across the entire usable range
10-23-2019, 03:54 AM | #13 |
Rep 948
10-23-2019, 10:30 AM | #14 |
Rep 108
Drives: 2015 BMW M5
A dyno measures power at the wheels, not the crank. Drivetrain loss can be anywhere from 10% to 15%, and is sometimes less/more depending upon the application. Mustang Dyno's are load bearing dynos and they typically read about 7% to 10% lower than a DynoJet or DynoPack. (Mustang Dyno's are great when you are tuning the vehicle.) Read up on differences between SAE (J1349) and STD. STD will typically be about 3% higher than the SAE calculation. Most shops want higher numbers and will usually post STD; it's all relative to how it's measured and how you want to look at it.
Being that those numbers are nearly what BMW says they are at the crank, (we all know that figure is apparently very underrated,) I'm guessing that your dyno pull posted was STD. Still, even if it were a Comp Pack, those are great numbers for stock.
2015 BMW F10 M5 | Competition Package | Driving Assistance Pkg | Executive Pkg | Bang & Olufsen | 343M 2NZ wheels
Born 02.27.2015 in Dingolfing |
Ickdeep5720.50 |
10-23-2019, 11:46 AM | #15 | |
Rep 948
10-23-2019, 10:47 PM | #16 |
274
Rep 541
F10MFive4Life4.50 Ickdeep5720.50 |
10-24-2019, 11:06 AM | #18 |
Rep 4,209
That's interesting. I guess its good to know what the engine is making to the crank but in the end of the day, its all about what power actually gets down to the road. Found this interesting article talking about the https://carfromjapan.com/article/ind...d-differences/
10-24-2019, 02:08 PM | #20 |
Rep 4,209
Correct but most people (I think) care about the WHP as that's the "real" number that hits the streets. BMW has been known for lowering their HP. For example, back in 2012 IND took a brand new M5 to the dyno (https://f10.m5post.com/forums/showthread.php?t=740823) . It came back with "527 wheel horsepower". If we convert that whp to hp (12% drivetrain loss) its 590 hp from the crank. BMW stated the engine was 553 hp.
10-24-2019, 02:57 PM | #21 |
Rep 948
I suppose the real question is still to be answered. Do mustang's read low and others read right or do mustang's read realistically and others read dream world numbers?
10-24-2019, 03:19 PM | #22 | ||
Rep 4,209
Source BerkTechnology : https://www.1addicts.com/forums/showthread.php?t=214597 Quote:
