10-25-2019, 01:36 AM | #1 |
Rep 140
Air Filter replace and maf sensor clean
So I decided to upgrade my intake part with limited budget. A high flow filter would be my first choice
From what I know, oiled filters may cause maf problem, so what I got is afe pro dry s filter. Driver side air intake box got stuck in the engine bay for some reason, I took 6 screws out and managed to take both charcoal filter and air filter out. It’s tough one honestly btw, the large screw that holds the driver side air box is t40 (should be t27 from I know) which is really weird Good bye dirty filter At this point I also took out maf sensors to see how dirty they were cuz my idle sometimes is erratic. There are some oil on the plastic cover (where is the oil from????) I found oil in the intake tube also. Can someone explain this? It took me 1hr or so to finish all this (driver side air intake box was really a pain ) I now can hear my turbo spool and feel slightly quicker throttle response For power gain, I don’t know since I don’t really wanna spend $$$ on dyno for some numeric data |
10-25-2019, 02:21 AM | #2 | |
274
Rep 541
and yea those non-euro spec charcoals suffocate the intake pretty good congrats on your first step on a very slippery slope! lol |
10-25-2019, 01:51 PM | #3 |
Rep 631
Drives: 2014 M6 Grand Coupe CP
There are two possible sources for the oil. One is the crank case breather system or a leaking turbo seal. The former is the more likely one given that it is also found on the air flow sensor.
F06 M6 Grand Coupe CP
Sapphire Black Metallic The drive is the destination |
10-26-2019, 04:55 PM | #4 |
Rep 140
10-26-2019, 04:58 PM | #5 |
Rep 140
Update: just got cel light on. No idrive warning. So I checked the code and it was 118011 and 118111, both are mixture control: mixture too rich.
They remove easily since they are not present when I pull over (My car is currently running on stage 1) Is it related to air filter change? Or should I ignore it? |
10-27-2019, 09:25 AM | #6 |
Rep 1,254
I have the same filters! Oddly, no oil in my intake though; didn't clean the mafs either although maybe I should give that a shot next time I'm in there.
2009 E92 M3 build thread: https://www.m3post.com/forums/showthread.php?t=1754875
Follow me on IG - www.instagram.com/the_driven_enthusiast |
12-20-2019, 02:51 PM | #8 |
Rep 648
Only use this to clean your MAF. I did this a few months back after getting a CEL. Check engine light came off immediately after cleaning the MAF.
12-20-2019, 03:35 PM | #9 |
60063
Rep 19,542
12-21-2019, 08:55 AM | #11 | |
Rep 648
M5Rick60062.50 |
12-21-2019, 12:24 PM | #12 |
60063
Rep 19,542
Thanks and it's good you don't have to wipe it with a cloth.Mine wasn't playing up or anything but with 35k miles it'll do no harm to clean them..preventative maintenance.
12-21-2019, 04:38 PM | #14 |
Rep 885
Did this yesterday. Only about 25k on the clock and has a lumpy cold start. Zero improvement so new plugs are on order.
DocRace 6266 E92. M8 comp coupe, X5m
06-28-2021, 05:07 PM | #15 |
Rep 5
I got the CEL with code E12C1C. I took the car to the dealer, they told me that it was the Mass Airflow sensor getting the wrong data because it was covered with oil all around. They found out that my crankcase ventilation hose is leaking so that I got some oil in the pipe.
They asked me $600 to replace the hose, which is fine for me. For the MAF sensor, they asked me $1.3k to replace them. Does it really need to be replaced? or I can just clean it myself? (My car is 45k miles and 8 years old.) |
06-30-2021, 08:05 PM | #17 |
Rep 3,140
Drives: 2014 M5 6MT
Get the Bosch mass air flow sensors from fcp euro. They are the exact part that comes in the bmw box ( part numbers are identical) and are a fraction of the cost.
2014 M5 6MT
07-01-2021, 02:05 PM | #18 |
Rep 5
Thanks for your replies!
They quoted me $1200 for MAF and $600 for Crankcase Vent Hose. And I also have the door actuator need to be replaced which was quoted $1100. I was lucky that my extend warranty approved everything, so I only need to pay $500 deductible. After replacing the MAF, the car runs very smooth when pressing the gas paddle. I will try to clean it every year thereafter |
