10-31-2019, 10:31 AM | #1 |
Rep 28
Drives: BMW F10 M5
SURVEY: Single Most Important Thing For F10 M5
Having recently taken ownership of a 'new-to-me' F10 M5; I've opened this thread in order to survey all SEASONED M5 owners. There's countless threads on mods, paint, wheels, DIY, suspension, tuning, detailing, etc... However, I'm simply asking for one's best and 'experienced' advice on what, in your opinion, would be the overall single most important thing to maintaining a healthy F10 M5.
Having said that, I think it's fair to include regrets; e.g., wish I hadn't "xyz" - lessons learned so to speak.
2015 M5 Competition - Suddenly Everybody Wants to Race...Most Lose
2011 BMW E92 M3 - Undeniably a Future Classic 2008 Corvette C6 - Loud/Red/Cammed-Out Ticket Magnet; Wife Hated It 2006 BMW E46 M3 CAB - Nothing Like the Top Down on a Summer Night |
10-31-2019, 11:25 AM | #2 | |
Rep 606
Drives: 2000 M5, 2001 M5, 2013 M5 6MT
Also, welcome and congrats on the purchase. |
Ickdeep5720.50 |
10-31-2019, 11:55 AM | #3 |
Rep 4,209
Drives: '13 F10 M5 | '15 F15 X5
Definitely do the service on time and for oil changes, do them at least every 5k miles.
10-31-2019, 12:52 PM | #5 |
17
Rep 31
Drive safe & don't crash. LOL.
Kidding aside. Here's something I'd share for perspective if you plan to mod the car. Things like catless DP and flash tunes make the car a lot more loud, fun and fast. But note that the added HP/TQ can greatly accelerate the wear and tear on many other stock components in the car that weren't designed to carry significantly higher HP/TQ loads, not to mention how the added vibration overall can cause more squeaks and noises in the cabin. The likely cumulative impact to many other stock components in the car - brakes and clutch for example - could require replacement far sooner than the normal expected lifespan of those stock parts, so keep this in mind. I realize one could argue that wear and tear / replacement requirements are subject to current mileage, style of driving etc. anyway. But in my POV, it doesn't change the rate at which parts on the car would need to be replaced, which is sped up considerably. |
10-31-2019, 02:06 PM | #6 |
60061
Rep 19,543
First one.Oil and filter changes more often definitely for engine longevity.
Second? Change those conservative standard drain pipe exhaust endings. |
10-31-2019, 04:30 PM | #7 | |
Rep 28
Drives: BMW F10 M5
10-31-2019, 04:31 PM | #8 |
Rep 28
Drives: BMW F10 M5
Any particular recommendations on your choice of oil?
10-31-2019, 04:45 PM | #9 |
Rep 4,209
I use liquid moly
11-01-2019, 04:13 PM | #10 |
112
Rep 385
The lack of a dipstick first the oil means you need to check in idrive. You need to actually check because the oil level sensor can fail and months can go by yet there is no loss in oil registered. If so, get the sensor and the oil replaced right away. Been there, done that,
Heat is a major concern on this engine hence it has no less than 7 radiators and two cooling circuits. The turbo circuit has small tank that has any easy to read level gauge in the tank. The main circuit tank also has a gauge except for US models! I use a tape measure set to exactly 6 inches as that is about the same as the metric spec in ETK. Neither of these two circuits have any warning system for "low coolant". The car is happy to pump it's entire coolant supply out and not let you know. Seen this happen in the driveway on my wife's 550i. Consequently, make sure to monitor your oil and coolant levels and get any leaks fixed right away as soon as you notice them. So often we read on these boards of people being very lazy (cheap really) about fixing leaks. One should not buy a depreciated $100K USD car and then act all phobic about spending some money to get things repaired. Keeping it healthy is just like with other cars, keep on top of fluid changes and watch for problems developing. |
BeachM5nster273.50 ticat9285.00 |
11-01-2019, 08:56 PM | #11 | |
Rep 28
Drives: BMW F10 M5
BeachM5nster273.50 |
11-05-2019, 04:29 PM | #13 |
Rep 108
Drives: 2015 BMW M5
Look up Ravenol 5w-40 Vollsynth Turbo, or VST. Look and compare the specs. If you find another with superior specs, let me know.
https://www.ravenol.de/en/product-ra...vst-sae-5w-40/ https://www.ravenolamerica.com/motor...nth-turbo-vst/
2015 BMW F10 M5 | Competition Package | Driving Assistance Pkg | Executive Pkg | Bang & Olufsen | 343M 2NZ wheels
Born 02.27.2015 in Dingolfing |
11-06-2019, 11:36 AM | #14 | |
Rep 20
https://www.ravenol.de/en/product-ra...ssl-sae-0w-40/ |
11-10-2019, 08:13 AM | #15 | |
274
Rep 541
always wondered that about the oil level sensor.. had no idea coolant had no sensor (new 7 series' have coolant level sensors. |
11-10-2019, 08:20 AM | #16 | |
274
Rep 541
11-13-2019, 02:11 AM | #17 | |
Rep 222
