12-27-2019, 10:50 AM | #1 |
M Enthusiast
36
Rep 171
Code Help
I ran a diagnostic today and was given the following codes. Anyone ever see these before and have recommendations?
140011 - Misfiring: Injection cut 118401 - Mixture ECU: Mixture too lean, large deviation 118010 - Mixture control, across the databases: mixture too lean 20E120 - Crankcase ventilation breather hose: not connected/defective |
12-27-2019, 11:07 AM | #2 | |
60063
Rep 19,542
12-27-2019, 06:08 PM | #3 | |
M Enthusiast
36
Rep 171
If there was a misfire code that popped up, would you just replace the spark plugs and maybe ignition coils? I replaced the spark plugs at 40k miles, so it's only been 20k miles, doesn't seem like much at all. |
12-28-2019, 01:16 PM | #4 | |
60063
Rep 19,542
60k now then, if it comes up again then yes the ign. coils may be starting to complain and they're not that expensive. Last edited by M5Rick; 12-28-2019 at 01:22 PM.. |
12-29-2019, 11:40 AM | #5 | |
M Enthusiast
36
Rep 171
9307A1 - my driver's door comfort access doesn't work anymore (I knew this) a couple codes referring to a CAN timeout (Info E14413 and Info 482740). Seems like there is some lag in time for communication between the DME and another system of the vehicle. Is that something to be concerned about? Weird that i got the CEL back on though. Maybe i have to drive it 50-100 miles?? |
12-29-2019, 12:27 PM | #6 | |
60063
Rep 19,542
Damn I'll clean those MAF's tomorrow if it kills me! |
J11SEK268.00 |
12-29-2019, 06:12 PM | #7 |
M Enthusiast
36
Rep 171
I'm so tired of these "ghost" error codes. I once had BMW do an inspection and the technician said he got like 15, insignificant codes that don't even mean anything lol
01-07-2020, 08:57 AM | #8 |
M Enthusiast
36
Rep 171
Update:
For the below codes: 118401 - Mixture ECU: Mixture too lean, large deviation 118010 - Mixture control, across the databases: mixture too lean Turns out i needed a fuel injector cleaner. The car was registering too much air and not enough fuel. Once i cleaned it out, the above codes went away. Just in case anyone gets the above codes. As for the misfire code, i have no idea why i'm getting it, there is literally no misfire at all. My breather hose was a bit loose so i snapped that back into place. |
01-07-2020, 05:47 PM | #9 | |
60063
Rep 19,542
01-08-2020, 08:50 AM | #10 |
M Enthusiast
36
Rep 171
So my CEL came back on and i failed the emissions test for my inspection. Looks like the fuel system failed emissions. Any recommendations? Could it be a bad oxygen sensor? I checked my air filters and it looks completely fine. It's not dirty and i made sure the filters have no cracks or holes.
01-08-2020, 10:44 AM | #11 | |
60063
Rep 19,542
01-08-2020, 11:52 AM | #12 | |
M Enthusiast
36
Rep 171
01-08-2020, 12:12 PM | #13 |
60063
Rep 19,542
Another poster mentioned it,you have to look down behind the fuel filler pipe rubber grommet.He said there's a breather pipe there..it's a tight fit though.
01-10-2020, 06:46 PM | #15 |
M Enthusiast
36
Rep 171
01-13-2020, 03:11 PM | #18 |
Rep 875
aayaz36.00 |
01-17-2020, 03:04 PM | #19 |
M Enthusiast
36
Rep 171
Update here: i checked the breather hoses and they were a bit oily inside and around the edges so i cleaned it off. CEL is off for now, hoping it doesnt come back.
01-30-2020, 02:52 PM | #20 |
M Enthusiast
36
Rep 171
Update here: i found the issue that was causing the CEL. It wasn't really the breather hose (at least not the only reason). My spark plugs were not "cold" enough to jive with the software tune and BMS intake that i had. I changed the plugs and cleaned the breather hose a couple weeks ago and haven't seen the CEL since.
