M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > M5 versus...
      06-17-2020, 02:30 PM   #1
Ickdeep
Ickdeep's Avatar
Drives: '13 F10 M5 | '15 F15 X5
2015 BMW X5  [10.00]
2013 BMW M5 [SOLD]  [10.00]
2013 BMW 535i [SOLD]  [10.00]
Best way to launch these cars?
Hello!
In about a month I'm going to my first dragstrip event (its digs and roll racing). I'm pretty solid with the rolling racings (40-60 mph) but I've struggled with getting this car off the line fast. I'm about to put a new set of tires on the car prior to the event (Michel PS4S). What are your recommendations to get this car off the line fast?
Thanks,
      06-22-2020, 12:57 PM   #2
jairomvp182
jairomvp182's Avatar
510
Drives: 22 X3MC
you need 315 proxes r888r and send it, they fit no need for spacers, also you can do any other tire on 305 and no need for spacers
22 X3m
10 e90 335i 610whp
13 M5, 11.0@131 Fabworx DP,Precision Tune 650whp+
11 E92 335xi 12.5@113MPH,362whp/438wtq GONE http://www.youtube.com/c/jairomvp
Instagram:Jairomvp
      06-22-2020, 02:24 PM   #3
Ickdeep
Ickdeep's Avatar
2015 BMW X5  [10.00]
Okay besides tires what else though? Like traction in MDM mode with everything on Sport Plus mode? Possibly holding the brake down a little and build boost?
      06-23-2020, 02:51 AM   #4
m5ssy
Drives: f10 M5
R888 tires. Another forum member had a thread outlined where he states to just hold the brake and then on the green light stomp the gas pedal with traction control off. As far as the settings I think leaving it in D with the highest shift setting works best (wont risk short shifting like in manual)
also: axle upgrade, oem seem to go out when running with a sticky tire
Ickdeep5720.50
      06-23-2020, 05:55 AM   #5
M5Rick
M5Rick's Avatar
60063
Drives: M5 F10 DCT Gunmetal
DSC on
I've tried all the methods and the best for me is, 305's,suspension on comfort, dsc on,no dynamic mode,g/box in D efficient and engine in efficient.No dramas it's just go using experience in throttle opening; With any other settings all you do is wear down the rear tyres whatever size they are and lots more chirping.Definitely no launch control.
*Just to add that we have seen on vids what dsc off can do when things don't go to plan.
Ickdeep5720.50
      06-23-2020, 06:54 AM   #6
vafan13
Drives: Sakhir Orange F10 M5
I haven't gone to the strip in mine, but based on my own experience, I would have comfort suspension, DSC off, sport+ throttle and then get some experience with the throttle to get the right wheel spin vs. power tradeoff.
comfort suspension so you get as much weight transfer to the rear wheels as possible
DSC off because even in MDM mode it will punish you. MDM will do better than Off if you just mash the throttle, but it will never be faster than a well-modulated pedal.
sport+ throttle because it appears to have the best throttle response for one's start/60ft time and modulation. I could also see an argument for Sport as while it seems to have a bit more delay, it's also less sensitive, which might make modulation easier.
That said, there are folks on here who have done a good amount of 1/4- and 1/2-mile runs. Would be nice to hear from them.
Ickdeep5720.50
      08-26-2021, 05:22 PM   #7
SlowestM5
SlowestM5's Avatar
9
Drives: 2018 BMW M5
2018 BMW M5  [10.00]
I tried launch control on mine and can't adjust the rpm with the cruise control buttons. it just revs to 7k. do I need a tune to activate factory launch control?
      03-17-2022, 07:19 AM   #8
dfields02
Drives: 2013 M5
Love the proxes
      05-13-2022, 11:12 PM   #9
fstm5
fstm5's Avatar
146
Drives: F10 M5
I have this issue too did you ever figure it out ?
Mine revs to 3k but I can't change it
      06-16-2022, 10:04 PM   #10
SlowestM5
SlowestM5's Avatar
9
Drives: 2018 BMW M5
2018 BMW M5  [10.00]
No couldn't figure it out.
      09-24-2022, 08:47 AM   #11
ARC550
Drives: M3, X5, 720s, X5, 750xi
Considering I have done this a few times lol.. to say the least.
Check out my video when I ran 10.3 some years back with M6 (record still stands)
Car had just Downpipes, tune, intake and 100 octane.
On track, best way is to just smash the gas!
Naturally the tires need to be heated and traction fully off.
The LC feature will modulate the gas and not give you that get up and go!
This 0-60 in video was 2.6
And all gears I manually shifted to avoid the car bouncing it off the rev limiter.
P.a you can hear my foot just mash the gas pedal!
Appreciate 3
fstm5145.50
M5Rick60062.50
1320racer135.00
      09-30-2022, 09:01 PM   #12
fstm5
fstm5's Avatar
146
Drives: F10 M5
2.6 ? Sheesh, stock axles /driveshaft ?
      09-30-2022, 09:04 PM   #13
ARC550
DSS axles.
Ssp clutch.
I broke multiple DSS axles
Read diff
And trans.
My advice.. use stock axles. If they break it's cheap.
If the DSS break, the diff and trans going with it ! lol
1320racer135.00
      09-30-2022, 11:31 PM   #14
fstm5
fstm5's Avatar
146
Drives: F10 M5
DSS axles.
Ssp clutch.
Read diff
And trans.
Damn how did you end up breaking the DSS axles ? That's surprising
      09-30-2022, 11:32 PM   #15
ARC550
DSS axles.
Ssp clutch.
Read diff
And trans.
Launch baby!!!
Car launches hard!! With my method.
fstm5145.50
      10-12-2022, 02:31 PM   #16
vafan13
Launch baby!!!
just watched the vid. awesome launch. What tires were you running for this?
Sakhir Orange F10 M5 | KW V3s | Dinan Swaybars | Turner Monoballs | Soul Exhaust | Mishimoto Oil Cooler
      10-12-2022, 02:33 PM   #17
ARC550
Launch baby!!!
R888 on 23 psi
1320racer135.00
m5post
